Question about Water Heaters
How can i fix or replace
Leaking water. appears to be coroded
  • Water Heaters Master
  • 5,245 Answers
Copy following link to determine source of leak
http://waterheatertimer.org/Leaking-water-heater.html
Add comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Apr 23, 2013
What is causing the water leak and how to fix it.
When water heaters start leaking, it's time to replace it. Check your warranty, maybe you can get a free replacement. Some models have a 10 year warranty. Good luck!
Feb 21, 2016 | Water Water Heaters
Rinnai heater problems
heat exchange leaking
Nov 21, 2017 | Water Heaters
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
Drain wont stop leaking
1) Copy following link for fixing drain valve on 38 gallon gas water heater with plastic drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
2) According to serial number, your GE (Rheem) water heater was made in 3rd month of 2007. No service manuals are available from Rheem. Warranty period is probably 6 year. Unit appears to have reliable White Rodgers gas control valve.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add comment and say what you discover.
Feb 18, 2013 | Water Heaters
WATER HEATER LEAKING
1) Copy following link for troubleshoot walk thru
2) Electric water heater might be leaking from element, and water appears at bottom of tank:
Feb 12, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is over flowing and coming out over the top of my hot water heater, i shut the water off and turned the temp down and turned the water back on after a few hours and water still is over flowing over...
If pipes are leaking, then that can be repaired.
If tank is rusted out and water escaping from the tank, then turn off the water plus power to the heater for safety, and then replace water heater.
Rusted water heater can be welded for repair, but remember that hot water is under pressure and tank can rupture any time.
Safest course if to replace heater.
Open following link for leaking water heater checklist:
Jul 27, 2011 | Whirlpool Water Heaters
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hi i a maxol MALAGA WATER HEATER gas only in my caravan it is leaking underneath help i need it fixed
If the water heater is leaking you have a rusted tank and it needs to be replaced. Turn off the water till it can be replaced. No fix for a rusted tank has to be replaced.
Jul 23, 2009 | Water Heaters
Boiler leak
Hi, it appears you have a defected relief valve. you can try one solution. lift the handle on the relief valve and let some water out. sometimes that can flush out materials thats blocking the stem in the valve. if it's still leaking it must be replace.
If this doesn’t work for you please write back. Thanks,
Nov 23, 2008 | Watts 3/4 Pressure Relief Valve
Water Heaters Logo
19 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
