Question about Aiwa AV-DV75
Aiwa compact disc /2disc player
This machine keeps shutting down power/after one minute.i tried the timer /tried the clock/tried setting even the clock no luck.also the stanby-light comes on shuts everything down.whenever this light comes on the whole unit shuts down.
  • 4 Answers
Same problem here...I determined that if you unplug the receiver for a few hours, it will work again for a week or so.  Someone else on this website said that it had something to do with the power relay switch:
http://www.fixya.com/support/t190750-aiwa_av_dv75_powers_off
Posted on May 31, 2008
SOURCE:
How do I change the time in a 1996 gmc jimmy sl radio
Setting the Clock for All Systems Except AM-FM Stereo with Compact Disc Player
Press SET. Within five seconds, press and hold SEEK until the correct minute appears on the display. Press and hold SCAN until the correct hour appears on the display.
Setting the Clock for AM-FM Stereo with Compact Disc Player
Press SET. (The radio may be on or off.) Within five seconds, press the SEEK right or left arrow until the correct minute appears on the display. Press and hold SCAN until the correct hour appears on the display.
Hope it helps
Apr 16, 2018 | GMC Cars & Trucks
Why does my AIWA CA-DW63OU turn itself ON by itself?
Could be a dirty power switch, or static electricity. Does it have an infrared remote? Maybe something in the room is triggering it. If so, try blocking the sensor.
Dec 22, 2017 | Aiwa Audio Players & Recorders
MY STEREO KEEPS TURNING ON AT 1 O'CLOCK EVER NIGHT???
Check with AIWA they might be able to supply the Operating instructions free. Some have them as a PDF on the website.
Dec 18, 2012 | Audio Players & Recorders
Aiwa XP-V7250C Compact Disc Player keeps flashing HO LD what to do?
luckily for you i have an awnser. unfortiantly i dont know how to spell the awnswer. so here ill try, the didsconekt on the bakch of the phone might may be bwroken and or reproducioneded try two pluge the phone into anothar sokcet in your walll.
Dec 22, 2011 | Aiwa XP-V7260C Personal CD Player
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
How do I set the snooze time?
Hello cazador1,
Lets get you setup with the automatic snooze function on the Aiwa FRA37 Clock Radio.
The manual for FRA37 can be found here.
On page 16 of 27 the information is as follows:
1. Set Alarm/Power to standby 2. Press the SLEEP button 3. The power will automatically come on and shut off after 59 minutes. 4. To set the time for sleep timer for a less amount of time Press SLOW repeatedly while holding SLEEP
To cancel the sleep timer press SLEEP OFF
I hope this helps you out!
A Pleasure,
Guide - Vexed Demon
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 13, 2011 | Aiwa FRA37 Clock Radio
It doesn't matter what you do, that the system will power down after being on for exactly a minute? Or do you find that when you try using it a few times in a row that the shut off happens a little sooner each time? Did this suddenly start happening or was it something that began occurring gradually (meaning it would power on for an hour and then auto shutoff)?
It sounds to me like some electrical component inside is failing and that the self-protection circuitry design is kicking in. Or it could be that the power transformer is worn out and can't maintain power for more than a minute.
Keep in mind that repairs to these older electronics can end up costing as much as it would be to buy a new unit (and new units offer much more technology anyway).
Dec 20, 2008 | Audio Players & Recorders
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Aiwa compact disc
I just noticed the date of this posting. Do you stilll need help or have you resolved your problem?
Bri
Aug 04, 2007 | Aiwa AV-DV75
Aiwa AV-DV75 Logo
91 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
