Question about Franklin Chef 85lb. Ice Maker FIM90
Franklin chef 85# ice machine problem
The machine will freeze ice, but it will not drop or harvest the ice before it sprays more water up on the ice causing it to freeze up. What could we do to solve this problem? Where can we get some type of schematic or troubleshooting information.
    Habit-Forming:
  • 193 Answers
Hot gas valve stuck closed,dead coil,low gas charge problem with defrost sensor
Posted on Apr 24, 2010
Water doesn;t stop
I don't know a lot about this machine but it could be that the water inlet value is not working correctly
Apr 07, 2014 | Franklin Industries Franklin Chef Ice Cube...
How do I clean my FLM70 ice maker
Google Franklin chef FIM70 Ice maker- compactAppliance.com, click on page scroll down page until you see Download product owner's manual ( PDF ) this will give you step by step instructions on how to clean your machine, The machine should be cleaned every 6 months. If cleaning dose not help with the problem than you need to look into a harvest problem.
Dec 04, 2013 | Franklin Industries Franklin Chef FIM200...
Machine runs cold water but will not make ice, pump runs and everything else works.
Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
Oct 01, 2013 | Franklin Industries Franklin Chef FIM200...
Ice freezing onto to upper plate and not dropping into bin machine doesn't cycle
Time to give it a good cleaning. If you use the wrong cleaner on the plate, it etches it and causes the cubes to stick.
Jan 05, 2011 | Franklin Industries Franklin Chef FIM200...
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that...
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Nov 24, 2010 | Franklin Industries Franklin Chef FIM200...
Hello Where can I get the Franklyn Chef Ice
fit a universal pump from any refrigeration parts shop and you will need to set the flow rate
Apr 22, 2010 | Franklin Industries Franklin Chef Ice Cube...
Franklin Chef 85lb. Ice Maker FIM90 Logo
414 people viewed this question
Top Franklin Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
niksparents
Level 1 Expert
marlin siecinski
Are you a Franklin Kitchen Appliances - Other Expert? Answer questions, earn points and help others
