Question about Panasonic KX-TG1033S Cordless Phone
I have talking caller-ID and I want to remove the "talking."
I have model KX-TG9344 with 4 handsets, voicemail and caller-ID. How do I remove the talkig caller-ID? kurtson@earthlink.net
  • 2 more comments
  • kurtson Mar 13, 2009
    I have unplugged all the base units form power, as I was directed and then waited for some time before replugging. However, the problem is still the same. There is still talking caller-ID. with that yelling voice which I need to have removed.
    I clicked on all the above but no change.
    I have done the scrolling down but no change.
  • kurtson Mar 16, 2009
    still no change. talking caller-ID persits.
  • 49 Answers
1 Go to Menu & Press #
2 Enter 1 6 2 then Press 0 to turn the Handset Caller Id off
3 Enter *1 6 2 then Press 0 to turn the Caller Id on the Base Station Off.
Posted on Mar 16, 2009
    Scholar:
  • 164 Answers
Hi;
1 {MENU}
2 Press {V} or {^} to select the desired menu. i {OK}
LIf there is a sub-menu(s), press {V} or {^} to select the desired item. i {OK}
3 Press {V} or {^} to select the desired setting. Press 3 to turn off the Caller voice ID{OK}
LThis step may vary depending on the feature being programmed.
4 {OFF}
Hope this helps,
Thanks.
    Sergeant:
  • 320 Answers
Read as per mentioned in the manual about the talking called id system:---- Talking Caller ID This feature lets you know who is calling without looking at the display. To use this feature, you must: – subscribe to Caller ID service of your service provider/telephone company.
Voice mail service Voice mail is an automatic answering service offered by your service provider/telephone company. After you subscribe to this service, your service provider/telephone company’s voice mail system answers calls for you when you are unavailable to answer the phone or when your line is busy. Messages are recorded by your service provider/telephone company, not your telephone. Please contact your service provider/telephone company for details of this service. Important: L To use the voice mail service provided by your service provider/telephone company rather than the unit’s answering system, turn off the answering system Storing the voice mail (VM) access number In order to listen to your voice mail messages, you must dial your service provider/telephone company’s voice mail access number. Once you have stored your voice mail access number, you can dial it automatically (page 41). 1 {MENU} i {#}{3}{3}{1} 2 Enter your access number (32 digits max.). i {Save} i {OFF} Note: L When storing your voice mail access number and your mailbox password, press {PAUSE} to add pauses (page 17) between the access number and the password as necessary. Contact your service provider/telephone company for the required pause time. Example: To erase the voice mail access number 1 {MENU} i {#}{3}{3}{1} 2 Press and hold {Clear} until all digits are erased. i {Save} i {OFF} Voice mail (VM) tone detection Your service provider/telephone company sends special signals (sometimes called “voice mail tones” or “stutter tones”) to the unit to let you know you have new voice mail messages. If you hear a series of dial tones followed by a continuous dial tone after you press {C}, you have new voice mail messages. Minutes after you hang up a call or after the phone stops ringing, your unit checks the phone line to see if new voice mail messages have been recorded. Turn this feature off when: – You do not subscribe to voice mail service. – Your service provider/telephone company does not send voice mail tones. – Your phone is connected to a PBX. If you are not sure which setting is required, contact your service provider/telephone company. Turning VM tone detection on/off The default setting is “On”. 1 {MENU} i {#}{3}{3}{2} 2 {V}/{^}: Select the desired setting. i {Save} i {OFF} 1-222-333-4444 VM access number Pauses Password PPPP 8888
to get all the details with proper instructions with exact system just click the above link and check from page number 30 its mentioned there  http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
the link is too big so it will take near to 4 minutes to get opened just click on the link and wait till it gets completely loaded. thanks.
Posted on Mar 13, 2009
  • 77 Answers
Greetings..... If i were you;
dont waste your money and pay for this... just trying to help but you can visit http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG1033S
Or you can call
Support: 1-800-211-PANA (7262)
en Español opcion #2
and they will walk you through it.
Hope this helps please take time to rate.
    Sergeant:
    Champion:
  • 435 Answers
Hi, You can change the caller id settings by calling your phone service provider. They should be able to guide you through it.
  • 3,037 Answers
Sounds like it may be a set ring tone. Have you looked into this? If not, go into the ring tone settings and change them and let me know how that works out.
Benjamin
  • 201 Answers
Press the 'Menu' key
Use the arrows to scroll down to the "Talking Caller ID' selection, then Hit "Select'
Use the arrows to change the value to "Off'
Press "Save"
Press "Off"
  • John Aman
    John Aman Mar 13, 2009
    Okay try this then:
    Make sure your base is plugged in. from the hand set, press MENU, #, 1620, SAVE, OFF.
    Sergeant:
  • 254 Answers
You will have to press this in the form
Talking
CallerID on
(Handset) ------{1}{6}{2} {1}: <On> {0}: Off – 31
Talking
CallerID on
(Base unit)------{*}{1}{6} -----{2} ----{1}: <On> {0}: Off r 31
  • 8,197 Answers
Go to this link on page 26 vit will tell you how to turn of or turn it on.
Good Luck and please Rate
Posted on Mar 12, 2009
  • 1 more comment
  • Jyackle5
    Jyackle5 Mar 12, 2009
    Talking
    CallerID
    (Handset)
    Talking
    CallerID
    (Base unit)
    {*}{1}{6}
    {2}
  • Jyackle5
    Jyackle5 Mar 13, 2009
    Hav you tried my link
  • Jyackle5
    Jyackle5 Mar 16, 2009
    Did my awnser solve your problem if so Please Rate Me
  • Panasonic Master
  • 19,396 Answers
Unplug all units from power for five minutes.
  • Ginko
    Ginko Mar 12, 2009
    To reset the system unplug all the base unit from power for a couple of minutes, if handset batteries are removable , then also remove the batteries from handsets at the same time.
    This will reset the system completely.
I suddenly have no Caller ID name, number and announcement. I have tried the manual that came with the phone. model KX-TG7624SK 6.0 Bluetooth Talking Caller ID Panasonic. I am tired of answering "cour
Ann also check with your telephone line provider for the land line calls that the subscribed service has been activated that forwards the calling line identity to your land phone line. Could be it somehow has become lost accidentally by the phone company.
It would be worth them checking it has not fallen off your subscriber settings to eliminate it as a possible cause)
Talking Caller ID Handset Dial #162 1 on 0 is off
Base Unit caller id Dial #*162 1 on 0 is off
Guess this toggles it from 1 or 0 in the settings
Jan 27, 2015 | Panasonic KX-TG7624SK DECT 6.0 Cordless...
How can troubleshoot the talking caller id to show on the handset
look in phone under menu then look for handset setup should be in there
Jun 05, 2014 | Panasonic KX-TG6541B Dect 6.0 Plus Digital...
ABOUT KX-TG6541
maybe if you ring the company name of the phone such as panasonic it maybe broken or read the instructions
Voicemail
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voicemail access code and press [SAVE].
Apr 22, 2014 | Panasonic KX-TG4753B DECT 6.0 Plus...
I am trying to set up my know phone model kxtg6545 and want to eliminate the caller announcement feature I do have voicemail and do not use the answering system please help
Talking Caller ID is enabled/disabled separately for the the base unit & handsets:
Handset - Menu # 1 6 2 0 - Save - then 'Off''
Base Unit - (From any handset keypad) Menu # * 1 6 2 0 - Save - then 'Off'
Feb 15, 2011 | Panasonic Cell Phones
My problem is i had purchased a panasonic 5.8 DIGITAL TALKING CALLER ID I WANT THE TALKING ID TO STOP IMMEDIATEDLY. IT IS ANNOYING THE HECK OUT OF ME
Page 25 of the owners manual says you can turn off talking caller id separately for the handset and base unit. For the handset, press [MENU], scroll to "Talk Caller ID" by pressing the down or up arrows, then press Select, then select "off" or "on", then press Save, then Off.
For the Handset, press [MENU], then scrol to "Initial setting", then press Select. Scroll to "Set base unit", press Select. Scroll to "Talk Caller ID", then press Select. Select "Off" or "On" by pressing up or down arrows.
Jan 13, 2009 | Panasonic KX-TG2336-S Phone
Panasonic KX-TG2357 talking caller ID
To turn Talking Caller ID on or off
You can turn Talking Caller ID on or off for the handset and base unit separately. If
this feature is off, the unit will not announce caller names. The factory preset is ON.
Handset Talking Caller ID feature
1 Press [MENU].
2 Scroll to “Talk Caller ID” by pressing [d]
or [B], then press Select.
3 Select “Off” or “On” by pressing [d] or [B].
4 Press Save, then press [OFF].
Also Refer To Page 31 Of Your Owners Manual.
If You Do Not Have The Owners Manual It Can Be Downloaded Here.
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Using Fixya.com
Oct 10, 2008 | Panasonic KX-TG2357 Cordless Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Cordless handset
They all have talking caller id on the phones themselves
Sep 28, 2007 | Panasonic KX-TG6053S Phone
Panasonic KX-TG1033S Cordless Phone Logo
303 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
