Question about Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer
How to change the metered machine to sold machine xerox 5225
Toner error , how to change a metered machine to a sold machine ?
  • 2072 Answers
SOURCE: i have xerox works center pro photo copier model
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
Posted on Dec 30, 2009
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
SOURCE: Have Xerox workcentre 5225/5230 and keeps beeping
error 010-327
Posted on Jun 20, 2010
  • 57 Answers
SOURCE: how to replace toner cartidge
The toner cartridge is located in the upper centre of the front of the copier. Open the front door, slide out the cartridge until you see the top handle, whilst pulling out hold the top handle to avoid the cartridge tilting and leaking any excess toner inside the machine.
Before inserting your new cartridge, gently shake it from side to side to ensure even distribution of the toner. Slide the new cartridge in until you here a click, then close the front door. Your copier may go into a calibration routine for a minute or so if the developer has been starved of toner. If it hasn't, it will be ready to copy straight away.
For a quick user guide on the copier go to http://download.support.xerox.com/pub/docs/WC5225_WC5230/userdocs/any-os/en/EN_Online5230_5225_5222_QUG.pdf
Hope this helps.
Posted on Jan 22, 2011
maxcarson
  • 7627 Answers
SOURCE: how to replace fuser web
You can find a user manual here: http://www.support.xerox.com/support/workcentre-5225/documentation/enus.html
Posted on Dec 12, 2012
HI ITS ALL OF A SUDDEN ASKED FOR A ENABLED METER TONER AND WANTS A PIN ???? HELP
this machine has the option of metered or non metered toner (sold toner)
are you under a contract ? did you just acquire this machine?
May 16, 2016 | Xerox Phaser 4500 Printer
How to converet Toner meterd chip to sold chip in xerox 5225
you can't convert it. only swap chips from old toners into new ones. although this is not recommended
Dec 29, 2014 | Xerox Office Equipment & Supplies
Xerox 7760 toner
Solutions for : How To Replace the Toner or Print Cartridge
This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered." In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Epson Printer Support Xerox Printer Support
Feb 26, 2014 | Office Equipment & Supplies
How to replace toner cartidge of the Xerox Copier 5225 machine?
Hope this helps.
Jan 21, 2011 | Xerox Workcentre 5225 / Copier, With...
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Hello. We have 2 Pcs of Xerox Copier
Try removing the fuser and re installing it.
If that doesnt work then the fuser is bad.
Nov 10, 2010 | Xerox DocuColor 3535 Copier
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
