Question about Garden
Bushranger lawnmower Repair Manual
The drive is not continuous. It will drive then stops for a short time then drives again. It appears that one tooth on a drive is missing
2 Suggested Answers
  • 402 Answers
SOURCE: Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Posted on Jun 02, 2010
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Why does my 1995 Lexus ES300 continuously stop when I drive it? I have run out of ideas
When the engine stalls;
Test for spark (ignition)
Test for fuel pressure & check fuel pump volume
Dec 30, 2014 | 1995 Lexus ES 300
Husqvarna 2548 trans axle stop moving after short time of moving i let it sit for short time moves again then stops again any common problems i should check/
check for oil level in the drive. There may be a problem in the drive pump or drive motors/ gearbox. If this is a mower with a hydrostatic drive then it may be the hydrostatic drive as they do fail on a regular basis.
Aug 30, 2014 | Cars & Trucks
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
Impeller dropped off. Replaced the hub but did it again.
maybe you should be using a washer and a nut to securely fix the plastic hub in place
Jul 13, 2017 | Garden
Jun 02, 2010 | Garden
94 chevy cav after driving short time car will
I would recommend replacing the in-line fuel filter
Nov 15, 2009 | 1994 Chevrolet Cavalier
MAXTOR 320 AUTOPLAY Problem
Another way to disable autoplay in XP (don't know if this works in other versions of Windows) is to click Start -> Run -> type "msconfig" -> click the Services tab -> and uncheck the selection called "Shell Hardware Detection". This will disable autoplay for not only all of your CD-ROM drives, but any other form of removable media (ie memory cards from your digital camera).
May 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
