Input not support aoc led e1621swb 15.6 monitor
I bought aoc 15.6 led e1621swb monitor but when I plug it on my pc which is windows xp the screen will normally run on boot but when the window will start loading the screen will display input not support pls help me resolve the issue with this. Do I have to install the monitor driver?or I have to return the monitor to the store?
4 Suggested Answers
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
Democritus
  • 120 Answers
SOURCE: new flat screen....
With your old monitor connected, set the display to 800x600 or 640x480 (or another low setting) and 60Hz (in advanced settings). Shut down completely. Connect your new monitor, and start up.
After windows boots, set the settings to where you want them. The refresh rate may be the problem here.
Posted on Mar 20, 2009
  • 121 Answers
SOURCE: display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
Posted on Nov 25, 2009
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
AOC monitor too bright!!!
Sounds like its T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD is given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 12, 2013 | AOC 19" LED Monitor e950Swn Black
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
No display
Try Unplugging the monitor and plugging back in again,,,you dont have to shut the PC down to do this,,,if it starts backup,,,then good... if it doesnt,,then you need another Monitor.
An LCD monitor is better for your eyes anyway.
Jan 19, 2009 | AOC 1556NB 15"
Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Dec 08, 2008 | Computers & Internet
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
