Question about Aiwa AV-DV75
Aiwa compact disc
This machine keeps shutting down power/after one minute.i tried the timer /tried the clock/tried setting even the clock no luck.
    Problem Solver:
  • 9 Answers
I just noticed the date of this posting. Do you stilll need help or have you resolved your problem?
Bri
Posted on Jun 10, 2008
Whay does my AIWA CA-DW63OU start playing by itself?
are you sure it's not going into demo mode after you turn it off? Is there just lights and display flashing? - that is demo mode. Probably a button on the remote to turn it off.
May 13, 2014 | Aiwa Audio Players & Recorders
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
Apr 07, 2014 | Audio Players & Recorders
MY STEREO KEEPS TURNING ON AT 1 O'CLOCK EVER NIGHT???
Check with AIWA they might be able to supply the Operating instructions free. Some have them as a PDF on the website.
Dec 18, 2012 | Audio Players & Recorders
How do I set the snooze time?
Hello cazador1,
Lets get you setup with the automatic snooze function on the Aiwa FRA37 Clock Radio.
The manual for FRA37 can be found here.
On page 16 of 27 the information is as follows:
1. Set Alarm/Power to standby 2. Press the SLEEP button 3. The power will automatically come on and shut off after 59 minutes. 4. To set the time for sleep timer for a less amount of time Press SLOW repeatedly while holding SLEEP
To cancel the sleep timer press SLEEP OFF
I hope this helps you out!
A Pleasure,
Guide - Vexed Demon
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 13, 2011 | Aiwa FRA37 Clock Radio
WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Jan 16, 2009 | General Electric WCVH6800J Front Load...
Aiwa compact disc /2disc player
It doesn't matter what you do, that the system will power down after being on for exactly a minute? Or do you find that when you try using it a few times in a row that the shut off happens a little sooner each time? Did this suddenly start happening or was it something that began occurring gradually (meaning it would power on for an hour and then auto shutoff)?
It sounds to me like some electrical component inside is failing and that the self-protection circuitry design is kicking in. Or it could be that the power transformer is worn out and can't maintain power for more than a minute.
Keep in mind that repairs to these older electronics can end up costing as much as it would be to buy a new unit (and new units offer much more technology anyway).
Dec 20, 2008 | Audio Players & Recorders
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Same problem here...I determined that if you unplug the receiver for a few hours, it will work again for a week or so.  Someone else on this website said that it had something to do with the power relay switch:
http://www.fixya.com/support/t190750-aiwa_av_dv75_powers_off
Aug 04, 2007 | Aiwa AV-DV75
Alarm clock radio feature
Before you do anything else, Cancel the Timer setting, which is activating the machine to start Playing in the afternoon. You will need the machine's Remote for this. On the Remote, Press TIMER repeatedly, while pressing SHIFT, till the Clock Symbol disappears from the Front Display. Now if you have to reset the Timer to play the machine at a different time - early morning, as you desire, follow these steps. First You have to make sure that the clock is set to the correct Time.Is it? Fine. If it is not,read trhe Owner's Manual and set it to the correct Time. Take note that you mark the AM or PM funtion properly. After the time is set correctly, You gotta set the clock to Switch On the set at a designated time in the morning. Follow the "Setting the Timer" instructions in the Manual to do so. Please do make the effort. I am here to help you, but I also do not encourage spoon feeding. You havta to some work yourself too. If you are still unable to do so, mail me at guptapravin@hotmail.com, and I shall send you step - by - step instructions Good Luck!
Sep 19, 2006 | Aiwa NSX-AJ310 Shelf System
Aiwa AV-DV75 Logo
108 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
