Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 error..15.004.45:38920
What does this mean:
Printer Error - Contact Service Report Fault 15.004.45:38920
  • 2,072 Answers
There are 2,, 150 watt halogen lamps that heat the drum. They are bad.
Xerox will sell you a heater assembly for about $250, you can fix it for less than $20. Any store that handles halogen lamps will have those, I normally get them at Lowes. but, if you can find he Sylvania brand, rated for 130 volts and vibration protected, purchase those, they are a little more expensive, but they are excellent. Still should be less than $15 a pair. I will just send you the instructions to avoid delay.Takes an hour to an hour and a half, its not hard, just requires you to remove a lot of things before you ge to those lamps, Taks your time and it will work fine.
First of all you will need Torx bits or drivers to remove the covers etc. I think mostly you will need a number 10 and 15 size.
First off you want to remove both side covers, there is one screw on the top back of the covers, and another on both covers, top front, you have to open the front paper path door to access the front screws. Then about the middle of the covers pull up and outward, they will kind of pop off, but thats fine, they have tabs on the bottom that can be pesky.
Remove the paper tray, the green maintenance tray and set aside.
Now remove the 2 green rails that the maintenance kit rides on. They both are held in by one screw. It will take some manupilating to get them out, but basically you push them sliightly back, inward and twist slightly until they come out. TAKE NOTE of how the leaf springs are on the rails, A hint when putting them back in, is to take some scotch tape and tape them on the side to keep them in place, You will see what I mean when you remove them. But its much easier to get the rails back in when those springs are taped to the side. And no worry about removing the tape afterward, I will have no affect on the machine if its left in.
Next, you look up and you will see a stainless steel curved plate. About 10 inches long and 3 inches high. There are 2 screws on the top of it that must be removed. There are 2 tabs on bottom, Once the screws are removed it just lifts out.
Now about midway up the paper path is the registration rollers. First, you have to go, ( looking from the front of the machine) to the left side of the machine, You will see a electromech clutch on a shaft with a 2 inch black gear with a belt attached. Remove the clip that holds the clutch on, slide off the gear and just let the belt drop in place.
Now, return to the front,The assembly is stainless steel, you will see a couple of rollers on it and some paper path actuators. There is one screw on the right side of that assembly that you need to remove, and on the left side, just by the bearing there is an "E" clip holding the bearing against the frame. remove the screw and the clip, Then move that transport CAREFULLY to the left and out. Be very careful to keep the 2 pieces together, there is a switch actuator that can be easily broken. So please take caution. On the right side, there will be a bearing that WILL fall out, and drop down into the paper feed area. Trust me it will do that. Just locate it and pick it up. When replacing that transport. I suggest, ( unless your considering suicide LOL) Put some white out or a little glue on the outside of that bearing when you press it back into the frame. Otherwise, IT WILL keep falling out and really try your patience. Just trust me on that one.
Now, look in the front , just above where the maintenance tray would go. You will see 2 screws, about 10 inches apart, They will be surounded by a beige/brownish plastic. Remove those 2 screws, they hold in the heater assembly you want to repair. When you remove those screws it will not yet come out, wiggle it a bit and look on the right side so you can easily determine the conectors, plugs you need to remove. Some have 1 some have 2.
Once you do that, slide that heater assembly downward and out. You will see the 2 lamps in there.
Take those little spring metal clips out,, replace BOTH lamps. Use some emery cloth to clean the contacts. Clean the reflector behind those lamps before replacing . That will make the heat transfer more efficient.
Once those are in , in reverse order reassamble. Just be cautious replacing that registration assembly so you dont break the black actuator.
It's really not hard, just takes some time. Give yourself an hour to an hour and a half. But that is your problem I guarantee it.
Posted on Mar 12, 2009
I get an error message that says "Printer Error - Contact Service: Report Fault:" Whats does it mean and how can I fix it? Thanks
That means the 2 halogen lamps that serve as the drum heater have gone out. Either one or both have blown.
They simply are 2, ,, 150 watt halogen lamps that you can replace, Takes about an hour to do, I can send you instructions if you want.
E-mail me ,,,
Jul 14, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Printer error 15.004.45:185233
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
Mar 12, 2009 | Xerox Phaser 8200 Laser Printer
Printer not working
That is a drum warm up fault. There are 2, 150 watt halogen lamps in the drum heater that blow.
If you want to replace them let me know, I will sent you the directions. I can pretty much say 100 percent that is the problem.
Feb 16, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200
Normally its the maintenance tray clutch slipping.
Or the maintenance tray ends are worn.
You can remove the left cover and clean the clutch, its on the lower part of the frame, and take your kit out and there are 2 tabs sticking out the ends that were on the last 1/4th inch.
The Printer's Front Panel Displays Printer Error - Report Fault: 07,005.47
The Drum Maintenance home sensor actuated, but not at the expected time. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts): The wiring harness from the clutch is not seated properly on the I/O Left board. Check all wiring connections to the I/O boards and verify. connectivity. TROUBLESHOOTING TIPS AND HINTS: Inspect the maintenance drawer lift pins for wear. See Service Bulletin #445 Rev #1 Replace Drum Maintenance Cam Followers for Inadequate Drum oiling Due to Worn-out Lift Pins. Run diagnostics to verify clutch and sensor operation. Also verify that the drum maintenance shaft is properly assembled. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 401087100 1 CLUTCH; LARGE,DM,SAFETY CONTROLLED 436041400 1 MAINTENANCE DRAWER W/10K ROLLER & COUNTER/PHASER 860/8200 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
May 05, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
582 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
