Question about D-Link DVC-2000 i2eye Video Conference
I 2 eye
I am all hooked up but the DIAL and SETTING on the front of the system an a large X how do I get rid of it. Also, I tried to get my IP address automatically .. and it won't do it... no one can call me can you help?
0 characters
1 Points
How do you conference in 2 separate #s? We tried: 1. Dial the 1st # 2. Press flash 3. Dial the 2nd # And how do you connect them on 1 call? Thank you!
This will depend upon whether your Polycom is connected to a PBX system or using a public landline. If using the Polycom through a PBX you may need to consult the system admin as you will often need to enter a 'conference code' before you dial the second party ie.
1. Dial the first party and ask them to hold
2. Press the Flash key
3. Dial the conference code for your system ie. #46
4. Dial the next party and ask them to hold
5. Press the Flash key twice and all parties are joined.
If you are using a public landline (ie. home phone line) then you will be limited to the conference services that your phone company provide and these are usually also accessed via a code. There are also conferencing services that for a fee you can dial into and follow the prompts to austomatically arrange your conference call.
May 17, 2011 | Polycom VoiceStation 300 Conference Phone
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
While i am receiving or dial a call from my 7936 Cisco ip phone other party and even i can not get any voice from both side. Only the dial ring is working. please dissolve this problem
Sounds like a classic "IP" routing problem. Make sure both end points can ping each other. The other possibility is a firewall issue where the firewall is blocking the RTP (voice) traffic.
May 21, 2010 | Cisco 7936 (cp7936ch1) Audio Conference
Mitel superconsole 1000
Yes, there are things you can do to clear the locked out phone.
~ The locked means something is wrong with the phone -or- wiring to the room from the Mitel system...
Locked out is like leaving your phone off hook too long, you get that irratating beeping noise, then when the beeping stops, the phone is locked out to save power going to the set.
Ok ~ the first thing I would try, go to the set and play with it, hang everything up and test to see if you can get dial tone... the next thing is change out the telephone set, and test.
If you changed out the telephone set, and there is still a trouble, there maybe a wiring issue, in which case you will require a cable tech to test connectivity...
Mar 23, 2009 | Mitel Conference Phones
Need to know if caller id can be manipulated in an avaya system?
That is something you have to set up with the line provider. Partner can not send caller ID information
Feb 18, 2009 | Avaya IP Office 4690...
Can You View what the Camera sees through a Computer?
i will connect with microsoft netmeeting just dial in your polycom ip adderss to it and it will connect if you have given private ip address to polycom then connect with private ip if given with public then with public ip adress .
Jul 31, 2008 | Polycom VSX 7000 Video Conference
Polycom soundstation 2W
I thought well I wonder what holding down other buttons would do to get rid of this cursed PLEASE WAIT issue.
I tried * and # together and hey presto it worked.
I did however have to go in and turn IP mode off.
Jan 07, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Dec 07, 2007 | Polycom SoundStation 2W (2200-07800-001)...
D-Link DVC-2000 i2eye Video Conference Logo
29 people viewed this question
Top D-Link Conference Phones Experts
Danny Nagdev
David Burbee
David Burbee
Are you a D-Link Conference Phone Expert? Answer questions, earn points and help others
