Question about Garden
Craftsman 6.5 ready start 917.376070
When I start the mower it idles fast and slow back and forth then when I go to mow it stops
  • 69 Answers
SOURCE: lawn mower won't work
Clean the carb out.
Posted on May 18, 2009
SOURCE: mower will not start and run
It was clogged and no fuel was getting to the engine, my son fixed it.
Thank You,
Bobbie
Posted on May 19, 2009
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
  • 8 Answers
SOURCE: Craftsman mower will not start without starting fluid
Sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure your float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish by reattaching the air filter support bracket making sure the gasket between the carb and the bracket isn't damaged. Also, never use last year gas, alway buy freah every year.
Posted on Jun 07, 2009
  • 74 Answers
SOURCE: lawn mower runs well from cold but if stopped won't start
Sounds like it's running rich. If the mixture is slightly rich it will start well when cold, but when hot it floods. Check the air cleaner to be sure it's not clogged/blocked. Get a new plug for it and if this happens again just install the new plug - the new plug won't be fouled with fuel. If it started with the new plug then you're on your way to a carb adjustment (that is if the air filter/cleaner is clean)
Posted on Aug 29, 2009
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
The blades stop turning under a heavy load on my Craftsman 42" mower deck. Is there an adjustment that can be made?
"the adjustment" is to slow down in high grass areas. alternatively mow more often so the grass does not get so high between mowings
Apr 12, 2011 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Mower will not stop when clutch is depressed
When you replaced the belt you either got a shorter belt or you have rerouted the belt wrong. You might try and get an original; belt and replace the one on the tractor. Good Luck-David
May 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
