What is the maxium supported ram for the ms6367 motherboard,I have just upgraded to 2.5GB but the computor won't re-boot and freezes.I had to take out the 512gb.th get it going.
    Scholar:
  • 77 Answers
According to the manufacturers specifications, this motherboard only officially supports up to 1.5 GB or RAM. It is also VERY important to remember that all RAM must be the same speed, any variation will most likely cause you some problems.
http://217.110.237.67/Manuals/6367-engl%20v1.0.pdf
Posted on Mar 12, 2009
I need help upgrading my Dell E93839 SCMO215 motherboard
support.dell.com
Look up you motherboard ,find out the maxium speed CPU that the board can handle. You may have a problem with the power supply beign too small. If runign Xp your Ram is already maxed out. Good luck.
Aug 26, 2014 | Computers & Internet
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
Asus sk8n motherboard. Trying to upgrade to 2 2gig cards. Crusial memory, they say will fit. Wont boot with the memory instaled. If I put them in both black or both blue slots freezes up. Cant get the biod...
The Kingston memory web site is an excellent source of memory spec information even if you don't buy their memory.
For the SK8N motherboard, they provide information on restrictions here: (click here)
Read the System Information tab to make sure that you're using the proper memory speed for the processor that you are using.
Apr 23, 2011 | ASUS SK8N Motherboard
Ecc ram in compaq Evo d300 won't work, is there a Ram setting in bios?... updated bios to 3.04
Hello mike59087, if you are having a problem with the 'RAM,' you should check to see if the 'System' support "ECC RAM." Next check to see if ie; you added more 'RAM' what type of RAM did you have in the computer before. You should see if the System is compatible with the different "Type: DDR, DDR2, DDR3, 512MB, 1GB, or 2GB; what is the [Maxium] RAM supported? Are the "Speeds different? 333Mhz, 2.1 GHz, 3.2 GHz... Is the RAM, Dual Layer, Double-sided... For the 'best performance; all RAM should be the 'same speed, from the 'same' manufacturer, the "total amount to add up to the "Maxium" supported RAM, and the 'same type: DDR, DDR2, or DDR3... Take a look at this website, it will give you a "quick scan, to see the type of RAM that is best to use with your 'system. "Thank for using Fix'Ya, and if this helped at all; click on the "Thumbs Up" to give a rating, thanks again, paul7of 9." Click Here: http://www.crucial.com/?gclid=CPqRvfLG4qUCFaVx5QodTzoM1A&cpe=pd_google_us&ef_id=ba5NApFYAQAAxxw:20101210204512:s
Dec 10, 2010 | Compaq (281946-001) for Evo D300...
How much RAM does D101ggc motherboard Support?
The Intel D101GGC Motherbord, has only two memory slots so it can take a maxium of 2GB.
Aug 11, 2010 | Intel D101GGC Motherboard
My computer will not boot up when I install more than 1 GB of RAM
dude i think its the prob with the motherboard ram slot try cleaning the slot and reinstalling the ram if then also it does not work i think its the prob with the motherboard slot !! and also make sure that if the ram is working by testing it in some other mobo .
Mar 04, 2010 | Soyo : SY-KT600 DRAGON PLUS V2 Socket...
Reseated memory ram both piece will work in slot 1 none will work in slot 2 and system will not boot when memory is in slot 2 any suggestion
Are you are exceeding the maxium total ram for this notebook? It will only accept a maximum of two 1GB modules.
Oct 31, 2009 | Dell Inspiron 1501 Notebook
Ram upgrade issue msi 845 pro motherboard
you should check bios for the ram settings, voltage and speed, they will be printed on the package the ram came in.
also, you don't want to mix ram up, they will run at the slowest ones speed.
also, most ram is used in pairs (2 at a time) using the 3, depending on the motherboard will give you errors.
try entering the bios on boot, and set the ram setting properly. you should see something that flashes on boot, like press f8 or del for bios. change your ram settings, save and exit. type back with your motherboard and ram model numbers if this solution did not work.
Jun 25, 2009 | MSI 845 PRO Motherboard
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
