Question about Garden
Cub cadet zr50 wont go foward - Garden
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 109 Answers
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Posted on May 03, 2009
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
retort
SOURCE: cub cadet weed eater wont stay running
air vent in gas cap pluged, push a pin through it
Posted on May 28, 2009
Cub cadet tank wont move once releasing the parking brake
Not sure what you are trying to do, but in order to push a Cub Cadet (when its not running), you need to put the transmission in ANY gear other than Neutral.
Jul 22, 2017 | Cub Cadet Garden
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
How do I adjust the chute on the cub cadet snow blower it only goes partway to one side and all the way on the other side
Un plug the chute control rod..put the chute in middle (foward) and the handle at 1 oclock and remount the chute rod..see at 3:40 on this video ===>
Feb 15, 2015 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
I have a cub cadet 2186 need to get pto off i wont come off crank
you will have to use large pulley puller to get off it should slide off no problem
Oct 06, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Z50
yes there most deffinately is if you cant find it take to dealer let them show were to fill and shoundnt cost anythimg most do to get your buisness
Sep 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
