Question about Refrigerators
EHB-191MK Compressor gone
A/C compressor noise
It could be the compressor or maybe the clutch has gone bad. to pinpoint the noise take off belt that goes to the compressor and then run the car and see if the noise is gone. If it is then you need to look at the compressor. If you have a gage you can check if there is any Freon left in the system. If it is before you replace the compressor you will need to take to shop to have it removed it is unlawful to let the Freon into the air.
May 06, 2014 | 2004 Toyota Tacoma
Tip
What is wrong when your refrigerator make a heavy buzz sound followed by a click...
Is that buzzing/click you hear from the compressor area?
If it is from their, the relay on the compressor has gone out, OR the compressor is locked up.To determine which of those it is the amprage draw using a amp meter clamped to the wire on the overload thermostat where the relay is, must be measured, if 17 or higher amps the compressor has locked up, if its around 5 or so the relay has gone out and replacing both relay and overload will fix it.If the compressor has locked that is a major repair and may cost up to $1200
Gene
on Aug 07, 2011 | Refrigerators
Fridge buzzes for a few seconds then you here a click. blew out coil area with compressed air. leaving unplugged to cool. no sure this will help. any ideas what is wrong? it is losing cool in the freezer.
If it is from their, the relay on the compressor has gone out, or the compressor is locked up.To determine which of those it is the amprage draw using a amp meter clamped to the wire on the overload where the relay is on the side of compressor must be measured if 17 or higher amps the compressor has locked up if its around 5 or so the relay has gone out and replacing both relay and overload will fix it.If the compressor has locked that is a major repair and may cost up to $1200
Gene
Aug 06, 2011 | Maytag MSD2756G Side by Side Refrigerator
Mitsubishi dxk09z3-s compressor doesnt fire up at all, cant check gas level. tried to force it on still nothing
it would have nothing to do with the gas. how old is it? it could be a few different things. the compressor is gone. the outside board is gone . or the wires from the board to compressor.. how did u try to force it on?
Nov 10, 2010 | Mitsubishi MS24WN Air Conditioner
Compressor gone & Input water line burned in half
Sounds like your condenser is dirty, condenser fan motor is out and it over heated the compressor. Since it get so hot, the plastic tubing is melted by the copper tubing ( plastic tubing is touching the hot copper tubing). It is not worth to fix it. Compressor cost $250-$300, plus condenser fan motor, plastic tubing and labor. U-Line has 5yr parts and labor sealed system Warr. U-Line ph # 800-779-2547
Jan 18, 2010 | U-Line Icemaker
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
99 model Expedition At first, the air bag was maximum high yesterday. so i disconnected the air supply hose from the bag to release all the air. after that, the air compressor doesn't work anymore... Now,...
I would say that the leveling sensor is most likely bad. But it won't matter untill you figure out why the compressor isn't working. You need to pick up a service manuel at the parts store, if you don't want to buy one somtimes you can check one out at the library. I am guessing and thats all I'm doing is that the leveling sensor is in front of the compressor and is not giving information to the compressor. Good Luck.
Jul 16, 2009 | 2000 Ford Expedition
AC compressor bad
If the compressor has gone bad again, it may be because the system didn't get flushed properly when it was first replaced or oil was not added. Before being done again, it must be flushed. This can only be done using special tools and materials. If you have that done, then you must replace the receiver/dryer, associated seals, refill the system with right amount of compressor oil, the compressor of course and then recharge the system. This is all assuming there are no leaks in the lines or the evaporator and condenser.
Mar 13, 2009 | 1994 Volvo 960
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
