Question about Dell Dimension 4500 PC Desktop
Computer will not start but shows no video
Error message: microprocessor failed bios test
The computer has to sticks of memory: 1 GB and 1 256.
The user states the video card is the orginial.
    Scholar:
  • 77 Answers
If you are getting a message that the microprocessor failed the bios test, then there is likely a serious problem with your processor. You can try removing the processor and then putting back in, as well as making sure the processor fan is working properly, but if that doesn't work, you will need a new CPU.
Posted on Mar 12, 2009
What are the dell beep codes for dell inspiron m5010
Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
Jun 17, 2014 | Dell Inspiron 15 Laptop Computer- Intel...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
Loose video cable connection or defective video cable.Faulty video adapter.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
May 15, 2011 | Dell Precision 530 PC Desktop
My dv6-1247 cl when i turn on the power it beep 8 times and the screen does not come on help
Yu will need to determine which BIOS you have a see below
The computer beeps several times
If you hear several beeps from the PC speaker, it means that the computer failed its power-on self test (POST) because a problem was detected. The POST is a procedure that tests several components such as power, BIOS, CPU, memory, and video. Only if all those tests pass, the computer will then allow the operating system to load. But if one or more of these tests fail, beeps indicate a problem and the boot process is halted. These errors are a little more difficult to troubleshoot.
To diagnose the problem, listen to the beeps carefully and write down the sequence. Is it one long beep? Is it several short beeps? How many? Once you have the beep sequence documented, you need to find out what it means. What BIOS do you have? When you first turn on the PC, look at the top of the first screen to find out. Common BIOS types are Award, Phoenix, and AMI.
Award:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beeps Most likely a RAM problemYou can find more detailed information about Award error messages on Award's web site.
Phoenix:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information 1-2-2-3 BIOS ROM Checksum 1-3-1-1 Test DRAM Refresh 1-3-1-3 Test Keyboard Controller 1-3-4-1 RAM Failure 1-3-4-3 RAM Failure 2-1-2-3 Check ROM Copyright Notice 2-2-3-1 Test for unexpected interrupts 1-3-4-3 RAM FailureYou can find more detailed information about Phoenix error messages on Phoenix's web site.
AMI:
1 beep Refresh failure 2 beeps Parity error 3 beeps Base 64K memory failure 4 beeps Timer not operational 5 beeps Processor error 6 beeps 8042 - gate A20 failure 7 beeps Processor exception interrupt error 8 beeps Display memory read/write failure 9 beeps ROM checksum error 10 beeps CMOS shutdown register read/write error 11 beeps Cache memory badYou can find more detailed information about AMI error messages on AMI's web site.
If you get beep errors, you should try to think what happened right before they started. Did you add a new piece of hardware? If so, it might be faulty or not installed right. Remove it, then try again. If everything is fine without the hardware, try to reinstall and configure the hardware again. If that does not help, try exchanging it and see if that corrects the problem. If the error persists, narrow it down systematically. Remove everything but the CPU, memory, keyboard, and video card, then boot again. Does the error still occur? If not, then add one piece of hardware and try again. Repeat until one new component causes the error and you now know who the culprit is. If yes, then reseat your CPU, memory and video card and try again. If the error still happens, try replacing the CPU, video card and memory one by one to see if one of them is the troublemaker. If that does not help, you could have a bad motherboard. Check the motherboard carefully for any signs of damage. Also check for shorts, a metallic object could have found its way onto the motherboard, or the motherboard is not installed correctly and touches the case somewhere.
Page 1: Computer boot problems
Page 2: This page
Page 3: System hanging after POST
Page 4: POST running OK but Windows not starting
Good luck
Please rate FIXYA
Thanks
Apr 02, 2011 | Computers & Internet
Working SG-72 MOBOs failing 1 by 1, no POST after BSOD, just fans
test the cpus in other machines. if your not getting any boot or beeps, then it is the bios or cpu.
Jun 30, 2009 | Abit SG-72 Motherboard
Asus 4 GB
windows xp will not show 4 gb of memory, it will support it but not show. you would need vista 64 bit to be shown the full 4gb of memory
Mar 16, 2009 | ASUS Eee PC 4GB Notebook
Computer will not boot - no signal getting to monitor
Have you check the video card, is it loose, not sitting right, beeps are either memory, video or a bad mobo. here's a list of beep codes; the numbers represent the amount of beeps
1   The memory refresh circuitry has failed 2   Parity errors have been detected in the first 64 KB of memory 3   A failure has occurred within the first 64 KB or memory 4   System Timer failure: Timer 1 on the mainboard does not work properly 5   The CPU has generated an undetectable error 6 8042 Gate-A20 failure: BIOS cannot switch the CPU into protected mode 7   The CPU has generated an exception error 8   The video adapter is missing, or the memory on the adapter has generated a failure 9   The ROM checksum value does not match the value in BIOS 10     The shutdown register for CMOS interrupt channel 2 has failed POST; the system board cannot retrieve CMOS contents during POST 11 Level-2 cache memory has failed the tests, and has been disabled 2 short POST has failed, caused by a failure of one of the hardware tests 1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered 1 long, 3 short Failure in video system: the video DAC, the monitor detection procedure or the video RAM has failed 1 long POST procedures have passed
Feb 21, 2009 | Asrock K7VM2 Motherboard
MEMORY UPGRADE
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 28, 2008 | Computers & Internet
Dell Dimension 4500 PC Desktop Logo
85 people viewed this question
Alun Cox
