Question about Pentair Kreepy Krauly Inground Automatic Cleaner
Disassemble kreepy krawly - Pentair Kreepy Krauly Inground Automatic Cleaner
My hurlcon CX 240 pool pump has good return pressure but very low suction from the pool and wont opperate the kreepy krawly, Do I need a new pump? Thanks. Richard
no
what you may have is a blocked outlet--filter --tap incorrectly set
good pressure but no suction indicates that the pump is pumping but the pumped water has nowhere to go
Jan 05, 2017 | Pool & Spa
Hurlcon pool pump. Lack of pressure. Creepy crawley will not pulsate. Pump working at 110 pressure - no change. Checked all joints with soapy water.
When you mention the 110 pressure with no change are you saying that the pump is operating at the same level as before and the Kreepy was functional with this level of pressure before? If this is the case then your problem is with the Kreepy itself. This sounds like something is in the Kreepy Krawly line or the unit itself. Many things can become lodged in the unit like acorns, bottle caps, or simply there is a leak in the vacuum hose. I would investigate the unit for impeding debris.
Dec 24, 2015 | Pool & Spa
Can i circulate my pump for whole day with kreepy attached?will it cause a problem?
using a krawly can cause damage to the pool surface (just for starters) as for running it for extended periods, i have some customers that let it run 24/7 unless they are swimming. there has been no damage to any part of the system to my knowledge
Oct 27, 2015 | Pool & Spa
I have great water pressure in my pool, but the minute I attach my Kreepy Krawly, the pressure drops and there is a large vacuum in the pump reservoir. the Kreepy hardly moves at all thereafter.
It sounds like your you might not have all of your suction lines closed. Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached. If this is not the problem, it could be that the pool pump and filter system that you have may be too small It should be capable of providing at least 25 gallons per minute. These are common issues with these pool cleaners.
Feb 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krawly keeps getting stuck in various corners of the pool. What should I do?
replace the little clear rubber pads on the feet and check to see if the side fins are working correctly
Sep 01, 2010 | Garden
I took my creepy apart and I can't get it back together. Could I have a schematic?
Your picture says that you have a baracuda, but if you have a kreepy I can help. Here is the owners manual for the Kreepy Krawly. These automatic pool cleaners are not hard to get back together with instructions.
http://www.backyardcitypools.com/images/pentair/kreepy_krauly_manual1.pdf
Jul 15, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
My kreepy krawly stays on the side of the pool and wont clean the bottom.I have placed the weights in the correct position. Any suggestions?
Try no weights.
Try weights in a incorrect position.
How is the hose....is it flexible......is it steering it to the sides and keeping it there?
Sep 30, 2009 | Universal Kreepy Krauly In-Ground Pool...
Pentair Kreepy Krauly Inground Automatic Cleaner Logo
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
