Question about LG WM2455HG XL Front Load Stackable Washing Machine with 9 Washing Programs
Lg tromm washing machine
Makes noise when draining or circulating
SOURCE: lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Posted on Mar 06, 2008
  • 3 Answers
SOURCE: I have a LG TROMM 4.0 WM2277HW
Normal 0 Thanks to other info gathered from this site and a few quality hours with the washer, I solved this problem for myself.
I experienced exactly the same problem. Did the same things. OE error Drain pump would not drain. Sounded like it was grinding a bit. Just not draining. Checked the strainer. Nothing. I found this link to the service repair manual which has easy to follow instructions on how to disassemble the washer and get to the pump. Removing the door and the pumps is really not that hard.
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Don't be scared. I'm a novice and it was easy. Wear gloves. Lots of sharp edges. All you really need is a screwdriver and pliers to remove hose clamps.
Anyway, I got the the top cover off, removed the front door panel section and could easily access the drain pump. I first pulled off all the hoses. All clear. Disconnected the pumps (easy once I figured out the clip the pump unit slides into). Note there are 2 pumps - a circulation pump and drain pump (larger one). All clear. Reassembled. Still nothing.
Ran a few loads of wash manually draining after each cycle (to keep the wife happy with clean laundry). Yes, you can do laundry while waiting on the part to be delivered. Just get a bucket and drain the washer after each cycle - easier if you pull off the main drain hose and drain it that way versus the little emergency drain slow (slow!).
Became convinced it must be the drain pump so I ordered a new one for $50 here. repairclinic.com
Installed new pump and reassembled machine in about 20 minutes. Worked great. NOW HERE IS SOME ADVICE THAT MIGHT SAVE YOU THE $50 for a PUMP:
After replacing the pump, I was banging on the old one to see why the heck it stopped working. During the process, I figured out how to actually pull the pump apart. There is a rubber washer around the housing below the blade - pull on it hard enough and the pump slides apart. When it did - holy cow! It was filled with grimy sandy muck. I cleaned it all out, but did not feel like testing it to see if worked. So I likely have a spare should the new one ever go out.
Hope this helps.
Good luck.
Posted on Mar 10, 2009
SOURCE: my lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Posted on Sep 20, 2009
localwonder
  • 6784 Answers
SOURCE: LG Tromm Washing Machine giving error code of IE
HI. This is a water inlet issue here.
Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes
First you will need to check the water fill faucets to make sure that they are turned all the way on.If the faucets are on, then move on to the hoses. Check the hoses for kinks. Make sure the hoses are straight, and not curved. If all checks out Ok here, i would advise to move on to the filter screens.
The hot and cold water from your home is connect to the water inlet valve on the back of the washer. In each end of the water supply hoses there may be a filter screen to catch debris and prevent it from damaging the washer. The water inlet valve also has filter screens. If the filter screens become clogged, the result is low water pressure, no water or the wrong water temperature,as well. The water inlet valve can be identified by the water hoses connecting to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting adequate water pressure and to clear any debris from the line.
Inspect the filter screens on both of the hoses and the inlet valve for debris build up. If you find any debris, clean it out. The screens in the inlet valve are not removable so use caution to avoid damaging them.
If you are getting good water pressure and you find no build up of debris, then the inlet valve itself may be faulty.
TESTING PROCEDURE FOR THE WATER VALVE ASSEMBLY
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first
NOTE:-(The water inlet valve can be identified by the water hoses connected to it at the back of the washer.)
(If the entire inlet system check out ok, and the hoses and valve are ok, replace the pressure switch, and pressure switch hose)
Posted on Nov 02, 2009
skimbot
  • 5 Answers
SOURCE: TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
Posted on May 30, 2010
Why won't my LG model WM2688HNM front load washer not drain? It spins and makes noise
sounds like a bad or clogged water pump but may also have to look the door switch which on some models wont allow it to spin or agitate? a bad motor coupler will not allow spinning or have bad weak spin cycle sorry cant be more specific by the way front loads tend to be a pain in the___ to work on good luck
Jul 26, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
LG TROMM washing machine can't open door
You need to unplug the machine, and drain the water from the drain hose, accessing the drain pump.
Once you access the drain pump also remove all obstructions in drain lines, this often fix teh problem.
If you do not have done anything similar before, then it is better to call the technician.
Jan 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Will not drain code OE
need to replace the drain pump motor,, this a common problem for LG washers, take it to an LG tech and have them replace the drain pump motor, not the circulation motor, there are two motors, dont be confused with the two. if not draining its the drain pump motor.
i would order a spare motor while your at it, it should be less than 60.00 for one. this is a common problem, i had replaced over a hundred so far.
good luck, n a feed back would be great........
Dec 14, 2008 | LG WM2688HWM TROMM SteamWasher
LG WM2455HG XL Front Load Stackable Washing Machine with 9 Washing Programs Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
