Question about Refrigerators
Baker hbf05e freezes keg no matter what setting the temp dial is at.
2 Suggested Answers
  • 117 Answers
SOURCE: true cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Posted on Jan 08, 2010
I have amagic chef 4.4 cu ft mini fridge. when I turn it on, no matter what I set dial to it freezes everything inside. How do I fix this ?
Hi.
This is a classic example of a faulty thermostat.
If it has a electronic controll system the temp sensor is defective.
Oct 28, 2015 | Refrigerators
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
True cooler frezzing kegs of beer
Jan 08, 2010 | True TBB-2 Beverage Cooler
Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
Jun 26, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Too much foam
well you are right the CO2 is causing the foam you may need to replace the regulator on the tank it is most likely bypassing the bellows inside...as a temp fix you can shut down the co2 and bleed off the air then just crack open the tank to (hand) regulate the flow ..
Feb 16, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
