Question about Monster HTS 5100 MKII Home Theatre Reference PowerCenter Surge
How do i get the right input on the hts5100
No signal.check the external input or select another input using the input button. how??
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Why am I getting a no signal alert? Top right corner says MDMI.
Check its input settings. Refer its user manual for details. Select the input as TV; and connect the external antenna; and check whether the TV receives any on-air signals. If not, its tuner is faulty. Contact any service technician to replace this part.
25278449-dozcisxt5ozbaqxvby5u5h52-4-0.jpg Electro help
Nov 11, 2014 | SEIKI Digital Seiki SE22FE01 22" 1080p...
Why would the tv say no signal
If you have selected an external input and there is no device connected and turned on, the TV will give this indication. Select another input (TV, HDMI, Video), or connect and turn on an external device. When there is a signal to the selected input, the "no signal" indication will go away, assuming the input is working correctly. I hope this helps.
May 09, 2014 | Televison & Video
Message reads "no signal check
select the right input in your TV set, depending on what kind of device you want to use or connect to access the device.hope will help you.
May 03, 2011 | Televison & Video
Connected computer to tv. it said no signal when i pushed the enter button
From the TV source or input menu you must select the input you wish to use. If using a laptop or PC you may need to switch it to using an external display device.
Apr 08, 2011 | Televison & Video
How do I change the input source without a remote control
There should be a button on the narrow edge on the right side of the TV labelled INPUT. Press this button once to bring up the input menu on the TV screen, you should then be able to highlight the input from this list using the CHANNEL UP/DOWN buttons on the side of the TV. It may actually be the VOL +/- buttons to move up and down the list - I can't honestly remember so you may need to try a couple of times to get it right.
Finally I think you need to press the INPUT button again to select the highlighted input
It's best to switch the external input device on before doing this so there is a signal to the TV. It's easier to see when you have selected the correct input this way.
If you still can't select the correct input, please let me know and I will check on the exact method for switching this TV without the remote. I'm working from memory here!
Hope this helps.
Regards,
BElectric.
Feb 05, 2011 | Polaroid TLA-01911C TV
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
My mackie d8b just stop picking up any input signals what could the problem be?
Make sure the mic/line button is selected when trying to input from teh external inputs.
Nov 01, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Monster HTS 5100 MKII Home Theatre Reference PowerCenter Surge Logo
18 people viewed this question
Top Monster Audio Players & Recorders Experts
Lawrence Oravetz
Phillip Hicks
Phillip Hicks
Bill Boyd
Are you a Monster Audio Player and Recorder Expert? Answer questions, earn points and help others
