Question about Epson Artisan 835 Wireless All-in-One Inkjet Printer
Horizontal lines on pages from Epson Artisan 835 printer
When printing I am getting several horizontal lines on the page. Can I clean a roller or something?
5 Suggested Answers
  • 139 Answers
SOURCE: Gray backround
Does your scanner software give the option to choose different modes...grayscale, color, black & white?? This sounds like it's scanning in grayscale....if you can change it to black & white, the background should remain white.
Posted on Jan 24, 2008
SOURCE: Epson 1290 printer
Fix posted yesterday BUT after a few perfect print outs the problem seems to be recurring.... will report back later. Trant
Posted on Mar 29, 2008
aicaxz
  • 511 Answers
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Posted on Jun 10, 2009
autotherapis
  • 501 Answers
SOURCE: i have a epson TX110
You need to go into the *properties icon on the print page and click on maintenance. Once you are in maintenance, click on clean print head and follow the directions. You may need to do it a few times to get it cleaned up if it has gone this far.
* go into a document and click on print as you would if you want to print it. when you are in the first print page, depending on your computer somewhere in the print box will be the properties icon.
Posted on Dec 03, 2009
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
Epson 835 printing only the top of the page being copyed
1. In Internet Explorer, try going to : 'File', 'Page setup' and check off the box for 'Print Background Colors and images'.
If does not work, go to:
2. In Internet Explorer go to 'Tools', 'Internet Options', go to 'Advanced' tab then go scroll down to 'Printing' and make sure box is checked for 'Print Background Color and images'.
3. If still not working, advise, you may need to take your ink out and use a syringe and mineral spirits to clean the heads of your printer (lots of times these get clogged).
4. All else fails, you can set your printer back to default settings, can find out how to do that over the internet.
One of these will fix your problem.
Jan 24, 2014 | Epson Artisan 835 Wireless All-in-One...
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Getting horizontal red streaks across printed page
The drum roller is damaged. You must be careful and spin the cylinder. do not touch the roller. You probably have a line in the roller that causes this issue. Each time i have seen this problem, this was the cause.
Feb 12, 2010 | Brother MFC-9840CDW Laser Printer
Dark lines appear on each page I print on the printer. I have cleaned every roller, dumped the old toner and added new toner.
Are the lines vertical or horizontal?
vertical lines can be caused by several things.
Since you said that cleaned the rollers, then here are other options
1: Most common is a bad toner cartridge.
2: try cleaning the fuser entrance guide.
3: could be a defective formatter - formatter replacement the fix.
4: worn fuser. fuser replacement is the fix.
horizontal lines are probably repetitive down the page, and are usually caused by a defective toner cartridge or fuser assembly. occasionaly a transfer roller will cause it as well.
Toner loves to get baked onto the fuser and cause all kinds of print problems. Not much you can do but to replace the fuser when this happens.
Oct 17, 2009 | OKI OL 400e Led Printer
Remove the cartridge(s) and use an alcohol swab to reach inside and clean the print head surface where the ink comes out.You may have to move the head with the power turned off to get at it or turn the printer on it's side to be able to reach under the head to clean. Q-tips work fine for that and it will likely take quite a few.Clean until there is no more ink on the q-tips. Also clean all rollers and surfaces where ink can collect. A defective head will also do that as it sometimes leaks excessive ink when printing.
Aug 29, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus photo 890 printer (5 years old)has
Do a cleaning several times. If that doesn't do it, then it is time to get a new printer. They are cheap enough and will be cheaper than bringing it to the repair shop.
Apr 22, 2009 | Epson Stylus CX9400 Photo Printer
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Artisan 835 Wireless All-in-One Inkjet Printer Logo
162 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
