Question about HP Deskjet 6940 InkJet Printer
My new black cartridge is producing smudgy type
There are smudgy lines running through my typing.
    President:
  • 2,692 Answers
E02820 Adj. Failed - Irregular alignment pattern
YOU MUST BE USING REFILLED CARTRIDGES. AFTER A COUPLE OF REFILLS THE TECHNOLOGY USED BY EPSON IS "BUBBLE JET" TYPE WHERE THE INK IS EJECTED/SPRAYED ON THE PAPER. after CONTINUAL RE-FILLS THE NOZZLE OF THE PRINT HEAD WIDENS, THUS GIVING YOU SMUDGY/SPRAYED TYPE OF PRINTOUTSW
Dec 10, 2013 | Canon Office Equipment & Supplies
Black lines across the page
hi there,
unplug cartridges and check its heads are clear if not take a tissue paper and cleane it very gantelly, intall the cartridges and run cleanning test from printer properties.
Jul 11, 2010 | Lexmark X2600 InkJet Printer
Replaced Black Cartridge...will not function
hi hello i tell you try replace that cartridge of yours. if your still use it, not working.. that cartridge is damage..
Jun 16, 2009 | Lexmark X1150 All-In-One InkJet Printer
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
Improper printing
Clean the cartridge or replace it.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Installed new black ink cartridge per instructions. HP #56 - machine type hp psc 2210 all-in-one. Machine instructed how to run cartridge alignmet check. In all modes machine runs about one half check and...
to complete the alignment it needs to detect the lines printed from both the black and colour cartridges.maybe ur black cartridge is printing the necessary pattern but the colour is not printing so when it tries to read the colour paattern ,it cant read and cancels the alignment and ejects the paper out..it will keep on doing this if it cannot read the both colour and black patterns.see to it that both ur cartridges are printing and working properly.
Dec 17, 2008 | Office Equipment & Supplies
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
SMUDGE LINES
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Aug 21, 2008 | Sharp AM-400 Digital Multifunction Printer
Color Printing Produces Pink Horizontal Lines
Hello we have had customers with this problem and this model printer We came upon this type of problem also exhibited the same lining when you did a nozzle check independant of the computer (not attached to computer and just using the internal head check print) This was a cartridge problem and after replacing the cartridge the problem stopped.
Apr 21, 2007 | Dell 962 Photo All-In-One InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
