Question about Sony DSR-11 DV / Mini DV VCR
Fast Forward and Rewind turn off machine
When i Fast Forward a mini-dv tape in my DSR-11 it makes a clicking sound then eventually powers down the entire machine...the same for rewind. nothing is wrong with the tapes..they don't come out scratched or eaten. any ideas?
    Genius:
  • 1,153 Answers
Your drive roller maybe slipping, this is the rubber-tire or it may be plastic driven gear type. If rubber you can clean that rubber with some type of cleaning fluid and dry and try again
Posted on Aug 16, 2007
SOURCE:
Tape loads into Sony DsR1500P but will not play or rewind/fast forward. No error code shown. Time code does not turn over.
Dear
Please play a head cleaning cassette and after using it for few seconds then play a normal tape.
Then it will show the picture.
Sep 10, 2013 | Sony DSR-1500 Mini DV VCR
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
Hi, after inserting a tape, the unit is in an endless cycle of trying and failing to rewind.
HI,
It will happen this type of problem.When your TG 2 Arm Assy and TG7 Arm AssyY SPRING, Extension is not in its place.Normally it should be in Center.checked and tape Tension
Feb 24, 2011 | Sony DSR-11 DV / Mini DV VCR
Squeaking sony dsr-11 in fast forward and rewind only. how do i fix?
First take of upper case and upper board ( board above mehanic) .From upper board take of conector from right said,two screw you have on that board.You can now take of board above.Plugged in tape,and  put tape in.Now you try to forward or rewind,and you can see the reason of damage and squeaking.Possible reasons are  driness of places with S and T reel tables. Also there are possbility of damaged capsten motor,and only solution is to put in a little fine mashin oil. Or maybe you can then,after all that,see another reason.Good luck,and I hope I helped you little bit. Don`t forget to wote! :-)
Oct 24, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR-11 will not record in DV SP mode.
dear, u need to change the memory cell of ur dsr-11 ,
Jul 29, 2009 | Sony DSR-11 DV / Mini DV VCR
NO TIMECODE , PICTURE & AUDIO
If the machice is dectable at the PC then the problem is with the head. Use a quality head cleaner cassette it will solve your proble.
Apr 30, 2009 | Sony DSR-45P DV / Mini DV VCR
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Apr 29, 2008 | Sony DSR-11 DV / Mini DV VCR
Can't eject tape that was just put in.
Your DC to DC converter start up with protection,It been disteract with something,you don`t have a part of power supply. If you have another DCR 11 you can change board JC 12. I think that is the problem. Good luck!
Oct 10, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-11 DV / Mini DV VCR Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
