Question about Refrigerators
I have a neff fridge freezer k4254x6gb/01 it is freezing the food in the fridge. Checked the drain hole it's clear thawed it all out for a day and still freezing the food. Took the lamp cover out inside fridge looking for thermostat doesn't seem to be there???
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 13, 2009
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
I have a 1996 Neff fridge E number K4513XOGB/01, enclosed in a cabinet. The drainage hole is blocked so water keeps overflowing on to fridge bottom shelf. We have tried to clear it with a cotton swab but...
Flexible PVC equipment wire or strimmer cord works.
Or something like a turkey baster- with plasticine to seal usually does the trick.
When clear, spray with a household cleaner to prevent mould growth.
Hope this provides a solution for you.
Jul 01, 2008 | Neff Refrigerators
Freezer works but the fridge area is not cool
Remove the bottom plastic liner on the freezer and look midways ont the backside for the hole where the drain is. If it has a slabe of ice over it unplug the freezer and let it thaw out. This will take a day or 2 to fix so have the food transfered elsewhere. After thaw out clear the drain. Remove the rear panel and check the fan operation. At that point if the fan is operating you can put the panels back on and wsee if clearing the drain is the problem. If it happens again in a few weeks then either the heater is bad or the defrost thermostat is bad. When either one of these go out the timer still goes into defrost but the heat does not. So what water dribbles down in them 21 minutes tends to pool up and freeze over. The evaporator gets clogged . The refrigerator has a blizzard up in the freezer and nothing happening below even though the fan is blowing full blast shaboom!
Dec 21, 2012 | Dryers
Condensation collects under the crisper drawers and needs to be cleaned out every few days. What is causing this?
Without a model number I can not be as specific as I would like.
If this is a top freezer model your defrost drain hole is clogged with ice or trash.
Remove the rear panel inside the freezer to access the drain hole. You should see a slab of ice in the back portion of the freezer. This will have to be completely thawed out. A hair dryer will help in thawing. Turn the fridge off. Melt the ice. Pour a 1/4 cup of bleach into the drain hole. Re-assemble the freezer components and turn the fridge back on.
This process will take an hour or more time.
If you have someplace to keep your food,you could unload the fridge. Turn it off. Leave the fridge off and the doors open overnight and it will self defrost.
Sep 05, 2009 | Refrigerators
Freezer thawed, fridge leaking. Our refrigerator
Without a type of Freezer, I take it it's a froze free type ? Check the drain for food clogging it or the drain pan and hose to it ( may have a hole in pan or hose. Wrap everything but be sure to clean the unit from food that lays at the bottom .
Jul 15, 2009 | Refrigerators
Same Problem ...Drain Hole Freezing up.
After facing the same issue (defrosting, cleaning the drain, drain gets blocked again...start again: defrost, etc..) I decided to try to give it one last go:
1. Defrost
2. Clean & rinse the drain (ensure is fully clean and I can pass liquid through the drain).
3. Get a ~30 cm pure copper wire
In my case I took a 3amp power cable, and took the copper wire from one of the cables.
4. Wrap one end of the copper wire around the copper coil at the back of the fridge (where the coil is warmest)
5. Insert the other end of the copper wire in the drain (just above the drip tray). I inserted ~15cm of wire into the drain.
The purpose of these last steps was to ensure there was no "freezing" happening on the drain. The copper effectively will keep the temperature inside the drain above freezing.
Not sure how permanent this might be.. so far at least I'm getting more months than with the previous symptoms treatments ;)
Best of luck!
Jul 09, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
GE Monogram refrigerator is leaking water on the floor
At some point the freezer got too cold and the drain froze (it is a poor design with a loop in the bottom). Once this freezes it will not thaw for a long time.
Here is what I did:
  • Remove all items from freezer and let it completely thaw
  • Pull unit away from wall to access rear
  • Cut loop off drain line where it hangs in drain pan
  • Place a bare copper wire (#12 will work) through the drain line and wrap it loosely around the heating coil above drain pan
  • Enjoy
Did this 6 months ago and have not had problem since
Mar 15, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Loud banging noise and water leaking
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market..
Dec 12, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
