Irrigation hydrotek 4000
At the base of the 4000 unit their are 4 openings 2 of which have lines coming out and going to a hydrotek 6000 and they go to the respective zones their are 12 zones each hydrotek has 6 ports or zone lines the 4000 switches between the two 6000s but at the base of the 4000 their are two ports open and every other cycle it just pours water out of the open port til that time cycle is complete the the next time it cycles on it goes to the next port in the 4000 and that goes to a line to the 6000 and is ok but after that cyle and it cuts off the next time it cycles on it pours water out of the open port so every other time the system come on it just pours water out on the ground by the units til the next cycle i tried to block them off and it builds up pressure and still didnt switch to the next zone what do i do the 3 units have all been rebuilt and they have the correct parts for the 4000 i kite and the 6ooo 2 kits so what can i do or what do i need
Buffalo12980
  • 625 Answers
SOURCE: HotPoint Top Loader model # WLW1500B
if you hear clicks then I'd have to say it was a mechanical timer. the timer has a small motor on it. a complete timer including its motor will run you about $120 but a replacement timer motor will be about $35.00
Posted on Sep 22, 2007
  • 38 Answers
SOURCE: Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Posted on Nov 05, 2008
  • 92 Answers
SOURCE: Short burn cycles
if thats a new themostst it sounds like you didnt set the cycle dip switches correctly,the type of heat you have is unknown to the thermostat so you have to tell it or it may short cycle or overheat
Posted on May 04, 2009
  • 197 Answers
SOURCE: Hotpoint WT761 washing machine - Error code F-10
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Posted on Sep 19, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I've noticed two problems with my heating system
Two problems, one is a bad thermostat on zone 2. The second is the boiler. The inducer fan energizes causing a pressure switch to engage. This pressure switch energizes the ignitor. If the ignitor does not get hot enough, it will cycle again all over. The cheapest route to take is to check all hoses going from fan housing to pressure switch looking for bad connections or leaks, the second thing to do is to replace your ignitor (time for it anyway).
Posted on Jan 06, 2010
How do I turn off Start time 2 on my Hardie 4000 irrigation controller?
have you tried turning it off all together then turn it on and then everything should flash no
May 25, 2014 | Garden
Tip
Drip it don't drop it
The popularity of Drip Irrigation Systems has been rising in the past years. It is true that this method of irrigation is usually a bit more expensive than sprinklers and isn't as resistant on the long run, but on the other hand the water saving and the system's efficiency definitely make it worth it. So why not giving it a try?
First of all, this system waters plants and flowers more slowly and the water goes straight to the roots, so no water goes to waste.
Moreover, it requires to be activated with less frequency than sprinklers.
In most countries it's one day of irrigation every week during the winter, two days during spring and fall and three during the summer.
Did you get one yet?
If you did here are two basic suggestions to start and keep up a satisfying drip irrigation system.
1. In order to figure out how long to leave it running, you can measure how much water your emitter produces and according to that and your plant's needs, set the system's timer.
So take a spoon and measure how many seconds the system takes to fill it up.
14 seconds = 1 gph (gallon per hour)
7 seconds = 2 gph
4 seconds = 4 gph
If your system is of the first kind, producing 1gph, usually you should leave it running for about 90 minutes, if it's the second (2gph) for about 60 minutes and if the third (4gph) for about 30 minutes.
(If your plants require a higher-flow emitter you can get one that produces up to 20 gph and leave it for about 12 minutes each watering.)
2. In order to keep your drip irrigation system in good shape check its line periodically for breaks, or its emitters for clogs.
Make sure that each emitter releases the right amount of water.
Also you should flush the drip irrigation lines and filters about twice each year. You can do this by uncapping the end cap on the drip line and letting water flush through the line.
on Sep 10, 2013 | Garden
Irrigation valve vibrates when opening.
Take apart and clean spring /diaphragm is sticking
Clean unt out
Feb 18, 2013 | Hunter Industries Hunter NODE-100 Single...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
I have a 98 TJ 2.5, does anyone know if it has another numbers in the chassi? (except the three plates inside the car) tnanks
hi no there is only the ones on the inside the layout should be like this for your one
1 Country of Origin 1 = United States 2 Make J = Jeep 3 Vehicle Type 4 = MPV 4 Gross Vehicle Weight Rating E = 3001-4000 lbs.
F = 4001-5000 lbs. 5 Vehicle Line Y = Wrangler 4×4 6 Series 1 = Sport
2 = SE
4 = Sahara 7 Body Style 9 = Open body 8 Engine P = 2.5L Unleaded Gasoline
S = 4.0L Unleaded Gasoline 9 Check Digit 0 through 9, or X 10 Model Year W = 1998 11 Assembly Plant P = Toledo #2 12-17 Vehicle Build Sequence Six Digit Number
incase the picture did not come out
2 Make J = Jeep
F = 4001-5000 lbs.
6 Series 1 = Sport
2 = SE
4 = Sahara
hope this helps.
Nov 13, 2010 | 1997 Jeep Wrangler
I have a siemens 4000 handset and I like to register it to a ssiemens 4215 base. Is that posible? Please help.
Yes. All DECT compatible handsets will register to a DECT compatible base unit.
If you have the manual for either phone, just follow the instructions.
If you dont, some manufacturers do have some odd quirks to the registration process, but most follow the following.
Look on the bottom of the base unit - there should be a 4 digit number somewhere. There will probably be lots of other longer numbers and bar codes also, but these are unrelated.
The base unit needs to be put in to registartion mode - usually done by either switching it off, waiting about 30 seconds, and then switching it on. Or, press and hold the base unit's page / find handset key. NB. the base unit stays in registartioon mode for about a minute, so if you dont complete the handset steps before this time, you have to start again.
Somewhere in the handsets menu will be a register handset option. On selecting this it will then ask for the 4 digit number above. Enter this, and after a short wait, the handset will be registered. Remember, this has to be done before the base unit times out.
Also note; base units can only register 4 or 5 handsets (depends on manufacturer), so if you've already got this number, you'll have to de-register one of the others first.
Sep 29, 2009 | Siemens Gigaset 4000 Phone
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
