Question about Furuno GP31 GPS Receiver
LCD furuno GP31
Lcd is brooken, how to i gate it this LCD
Even Im facing the same problem, when I gave it for repairs, they says that the screen is moulded with Body, hence it cannot be repaired.
Posted on Sep 22, 2009
  • 463 Answers
Contact your local West Marine, Boater's World or contact Furuno directly.
http://www.furuno.com/
Posted on Mar 12, 2009
Hello, I have a GPS FURUNO GP31 and his screen is out of service and I want to retrieve the data. You can do this ? because I am on vacation until Saturday, August 2 sydney.or i go to melbourne until...
I have posted the Operator Manual at
http://www.offscotland.plus.com/Temp/GP30-GP35-Operator's_Manual.pdf
Use this to check out section 7-10 to make up a cable to connect to a PC to allow download of data. Then, using the manual as a reference figure out the sequence of buttons to press to get the GP31 to download the waypoint and route data to the PC. Just press the buttons and assume the display is showing the next prompt. If you know someone you has a working GP31 get them to do the sequence and write down the buttons they press. You just copy the same sequence. You will need some software on the PC to capture the data,
Jul 30, 2014 | Furuno GP31 GPS Receiver
Need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Jun 30, 2010 | Furuno GP31 GPS Receiver
Radar install problem
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
Mar 23, 2009 | Furuno 1833C/NT GPS Receiver
I've just bought a boat with a furuno gp 31 , no user manual .is there somewhere I can download one thanks.
Hello!
You can download one here:
http://www.furunousa.com/Furuno/Doc/0/5OS1KKAL2OP434ND790LNUEPEB/GP31-GP36%20Operator%27s%20Manual%20%20k.pdf
Copy the entire link into your browser and you should have it.  It is in PDF format, so if you need a PDF reader, go to www.adobe.com and get one for free.
Hope this helps,
Ken
Dec 06, 2008 | Furuno GP31 GPS Receiver
Can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC.  With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Hope this helps you out,
Ken
Sep 19, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 - PC wiring instructions
try
http://furuno.inforce.dk/graphics/14_Softwares/09_gps/FURUNO_GP-32_pc_connect.pdf
Jun 27, 2008 | Furuno GP31 GPS Receiver
Furuno gp31
i dont think you should have a fuse on the - wire its only a return to earth its like closing the stable door after the horse as bolted
May 11, 2008 | Furuno GP31 GPS Receiver
Furuno gps gp 32
The only place to get that screen is through a Furuno authorized dealer. The unit is sealed and gas filled to remain waterproof. You're best bet would be to send the unit in to Furuno for repair. You wont save much doing it yourself because the cost of the screen makes up most of the cost of the repair. They will also make sure that all the software is up to date for the new WAAS satellites that recently went on line.
Have you tried adjusting the contrast? On that model I believe you tap the power key while the unit is on and you will see 2 sliding scales on the screen, one for brightness and one for contrast. Up or down arrows select the scale and left or right arrows adjust it. If the contrast and brightmness aren't tied into the power key on that model, they're somewhere in the set up menu.
If adjusting the contrast doesn't help then the screen has most likely failed. This is commonly caused by old age, however repeated exposure to extreme heat or cold can cause premature failure.
Jan 25, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 GPS Receiver Logo
330 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
