Question about Vehicle Parts & Accessories
Tailgate brake lights dont wor
Brake lights on tailgate do not work but over cab brake light does. Blinkers work fine and fuse is ok
  • 4 Answers
Your brake light switch has 2 sets of contact's. it's more les a fail safe. If your able to ck make sure brake light fuse is good. if so then your brake switch on the pedal is bad.
Posted on May 19, 2013
2 Suggested Answers
spindelart
  • 19 Answers
SOURCE: left side tail light on 2000 gmc sonoma only has turn and brake signal no driving light put good bulb in still dont work.
better check your bulb a little better,or try a different one,the turn signal and brake work on the same circuit,that is either a 3157 bulb or a round base 1157,check both strands in the bulb if one is broken you will see it,if not try a different bulb just for the hell of it, otherwise you have a wire problem!
Posted on Mar 06, 2013
My left brake light and brake light over the tailgate stopped working on my 2008 Aspen. I replaced the bulb on the light over the tailgate and it works fine now. However, I also replaced the bulb on the...
Sometimes the wiring will go bad in the light assembly check all fuses under dash and under hood. sometimes have individual fuses for each tail light. otherwise check wiring.
Jun 28, 2012 | 2008 Chrysler Aspen
No brake lights, upper brake light on tailgate works, changed bulbs and fuses
If fuse #34 in the rear fuse panel is OK, then problem has to be in the tail lamp circuit board at each rear corner, or in the wiring.
Sep 18, 2011 | 2004 Chevrolet TrailBlazer
Brake lights by the tailgate not working. the brake light on the back of the cab works. just had a stop light switch put in about a week ago because none of the brake lights worked. That fixed the problem,...
I meant to tell you also to check the wires to the newly installed brake light switch to see if the wiring is connected securely. Ity maybe loose in the connector also
May 30, 2010 | Chevrolet C1500 Cars & Trucks
Tail gate light constanly on
Recheck the fuse or just replace it if this circute is fused,
I have run across fuses that have had a hairline break and look ok.
Also check your wiring connectors for corrosion.
May 20, 2010 | 2006 Honda CBR 125 R
I actually have three issues electrically with my 2005 Envoy XUV. The most important one is the running lights. First the running light feed to the trailer connection ( factory installed ) fed no power to...
1) Look for fuse 32 in underhood fuse panel, I believe this is for trailer lights. 50 & 51 are for R and L trailer brake.
2) The blower resistor pack is defective, this is located behind the glovebox and mounted to the blower body.
3) I have no solution for tailgate problem, suggest visiting Trailvoy.com forum and doing search on XUV tailgate.
Sep 14, 2009 | 2005 GMC Envoy
Hi, i have a 206HDI 51 plate and for some reason my brake lights (O/S N/S and tailgate)have stopped working. i've changed fuses but still no joy, bulbs also seem to be ok. All the other light are working...
Check the brake switch, located on the break pedal. Connect the 2 wires together and if the break lights work, a new switch is required.(if only 1 wire connect to frame/chassis)
Jul 26, 2009 | 1991 Peugeot 405
Turn signals work but the brake lights do not how do i get them to work? i already changed the flasher.
I have a 2001 Ford F150, my brake lights dont work. Ive replaced the bulbs, checked the fuses,and the brake switch on side of the brake pedal was replaced. I still dont have any brake lights. My third brake light works fine, along with my running lights,flashers, blinkers.
Jun 18, 2009 | 1985 Ford F150
I need to change the brakelight on my 2001 gmc sierra?
Which Brake line are we Talking about. The one from the Master Cylinder or one from a Caliper on??????????
Jan 23, 2009 | 2001 GMC Sierra Crew Cab
Audi a3 rear brake light fault
the dealer can fix this or any mechanic with a vag com interface, basically its a matter of programing the tailgate lights (both of them) to work as brake lights. the euro speck enables one of the other or both, same goes for the backup light. if you had a module replaced recently this could be the reason for the change, whoever installed it should be able to rectify this for you.
Sep 23, 2008 | 2005 Audi A3
Vehicle Parts & Accessories Logo
105 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
