Question about Garden
Adjust belt tension 42 in. troy bilt mower
Belt keeps coming off the pully
MNfisherman
  • 11896 Answers
SOURCE: The deck belt keeps falling
Either the belt is stretched out and needs to be replaced or there is an idler/tensioner pulley that may be weak and not putting enough pressure on the belt.
Posted on Jun 30, 2010
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
  • 12 Answers
SOURCE: Had to change the small drive belt that drives the
You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
Posted on May 03, 2010
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
  • 3911 Answers
SOURCE: I have a troy bilt pony and the drive belt to
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Posted on Apr 06, 2011
How to change the transmission drive belt on a Troy-Bilt riding mower
IF YOUR MOWER COMES EITHER TRANSMISION AMD DRIVE BELT OR ONE EXTENDED BELT, YOU HAVE TO LOSE THE CUTTING DECK AND DISMOUNT THE OLD BELT, TO REPLACE THE NEW ONE FOLLOW THE DRAWING NORMALLY PRINTED ONYSTHE DECK ADJUST TENSION WHEN YOU MOUNT BACK THE CUTTING DECKALOWING THE BELT TO BE LOOSE A LITTLE, BY PUSHING THE ONE PART OF THE BELT IN BETWEEN PULLEYS FOR A ONE INCH OF PLAY AND YOU ARE SET.
Jul 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    Drive belt problem
    ck var speed pulley for movement on middle part
    of pulley
    Jul 29, 2009 | Garden
    My belt wnat stay on my 42 inch cut troy bilt riding lawn mower, why?
    Usually, it's because the belt's worn out. Over a period of time, they stretch and wear against the pullys. I recently replaced one after it came off several times. Try as I might, I couldn't see anything wrong with the belt. I changed it anyway, and it's run fine ever since!!
    Good luck! --W/D--
    Jul 16, 2009 | Troy Garden
    Troy Bilt self propelled mower
    Cribrat 1;
    Please don't be offended but are you sure you are putting it on the right way. A lot of the mowers out today have guards that prevent the belt from coming off the pulleys if there is a foreign object caught up when they are being used. These guards are actually post that are fastened to the chassis of the mower. Troy built is a top name mower so I'm sure their design is reliable. Sorry I can't be more specific.
    Does the tension on the belt seem adequate? Is there a tension adjustment. (an idler pulley with an adjustment)?
    Hope this helps Good Luck Loring Please give me a rating Thks
    Oct 29, 2008 | Troy Bilt 5.5hp Self Propelled Mower
    Garden Logo
    242 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
