Question about Garden
Countyline rotary tiller
When I lower the tiller to the ground the blades dont bite. The PTO rpms are at the recomended rate. Do I need to replace the gear box? If so how much would one cost?
5 Suggested Answers
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
  • 22 Answers
SOURCE: I have a troy-built rear blade tiller. It starts
Your belt is likely slipping. To adjust the belts, slide the block down that the roller on the forward/reverse lever uses to lock the tiller into forward. Use a 9/16" wrench to loosen the bolt on the backside of the block, then slide the block down a bit and retighten the bolt. If it's not the belt slipping, you've got transmission gear or bearing problems that could be costly to repair. I hope it's the simple adjustment.
Posted on Jun 16, 2009
SOURCE: I just got a 5' KK rotary tiller and the pto shaft
http://www.youtube.cohttp://www.everythingattachments.com/Tractor
http://www.everythingattachments.com/Tractor-3-Point-Hitch-Tillers-Rotary-Tillers-s/76.htm
go to the second site first, it will explain your "problem.". Your problem is you need to adjust the length of the pto shaft to your particular application. not all pto shafts fit all attachments "out of the chute"
once the shaft is adjusted OR prio to modifying it, view the first video. both or very well presented. i've been there!
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Posted on Mar 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: where do I find part numbers for my Ariens TR424
Go to this page: http://www.jackssmallengines.com/help.cfm
The choose menus:
Airens
Front tine tillers
RT424 4hp (note model and serial numbers!) pick yours
It will be 902026-xxxxxxx x= your number
There are 2 gearbox part numbers
1. 00201400
http://www.jackssmallengines.com/searchdb2.cfm?arisku=00201400&aribrand=Ariens&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dS4JA%252bvDiuhxnRQKPG3HpjA%253d%253dariamparica%253dVW4ZVMgDKUJOh%252fyuxQghxw%253d%253dariamparioem%253dT5AoXrwJ%252fdc5PmlGuX535Q%253d%253dariamparit%253dac83beea-d9ce-4586-92eb-5b37a36e4d95&ariqty=1
And
00287100 (Aluminum)
http://www.jackssmallengines.com/searchdb2.cfm?arisku=00287100&aribrand=Ariens&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dwRJIs3RYfQcbYmA%252bu%252bdCDA%253d%253dariamparica%253dYcaPzWhKx8%252f17NVu3Eh%252bXA%253d%253dariamparioem%253dlDrUqX7mT9VVQe1v8FlYOg%253d%253dariamparit%253d0713aa56-cc1e-4998-a4d2-4938cb172940&ariqty=1
That should be what your looking for. All of the seals and bearings can be found there also using the tedious menu search then selecting gearcase at the top of the picture.
Thanks for choosing FixYa.
Kelly
P.s I tried a net search for just the gearbox part number 00287100 with only one result. Seems you will have to use the menus.
Posted on Sep 03, 2010
Testimonial: "Thank you very much. I have now managed to find the part I want and it is being ordered. Hopefully delivered in 5 days. Cheers Jim"
John Deere x300 series 2009 model I unhooked the kill wire and it started. But now my mower/pto will not engage is there a way to bypass the sensor?
Based on the combination problems involving the coil kill wire and the PTO activation, I would suspect the PTO switch is bad.
I do not have a schematic for the 300x, however I most of the functions are comparable to the LA 145, 165, 175.
The PTO switch is a multifunction switch. It will have 3 to 4 different functions internally. On the LA 175 it serves 3 functions. These 3 internal functions are independent of one another. Electronically they are known as single pole/single throw switches. In other words even though they are all housed inside a single unit they act light 3 separate light switches in your house.
One function ("light switch") controls your cranking system. When the key is turned to Start, power flows from the Key switch (purple wire) to the PTO switch. With the PTO switch off it flow out (purple/white) and goes to the Brake switch. If the Brake is set the power flows through to the starter solenoid and your engine cranks.
Another "light switch" inside the PTO switch controls the Blade Clutch. Power flows from the Key switch, in run position, (yellow wire) to the PTO switch. With the PTO switch on it flows out another yellow wire to the Blade Clutch. A DC volt meter should show 12 volts switching on and off as the PTO is turned on and off.
The third "light switch" completes a Ground Path. This ground path is a totally separate pathway running through the PTO switch. The ground system is fairly complex because it operates differently under different scenarios.
To produce a spark, the key switch must be in the start or run position. While starting the PTO must be off and the brake set. The seat switch does not matter at this point.
Once the engine is running the seat switch plays a part if the PTO is activated or the Brake is released. Someone must be in the seat.
The Kill system is activated
  1. When the key switch is turned off.
  2. When the operator leaves the seat without setting the brake and turning off the PTO.
  3. When the machine is reversed while the PTO is engaged and the back up switch (RIS) is not pressed.
So there are three different paths to ground; any of which can kill the engine by grounding the coil. Except for turning off the key, all other grounding functions flow through the "grounding light switch" in the PTO.
Because you have a combination problem, the Coil kill wire is grounding the engine and the Blade Clutch won't activate the blades; both of which are affected by the PTO switch, odds are you have a bad PTO.
Obviously there are too many complex functions to just bypass the switch. You will have to replace it. The part number you need is AM135131. You can do a site search to locate and order this replacement switch for about $26.00 including shipping at this site: GreenPartStore Parts for John Deere Lawn Tractors John Deere Lawn Garden...
Mar 29, 2015 | John Deere Garden
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
Is there a shear bolt on the caroni tiller 5ft?
Yes all tillers and snow blowers that size need shear bolts in the tiller in the case it would get stones lodged between the tiller blades and the shield..or packed snow,ice or even stones in the auger ,..you may get away with using a soft steel bolt but sooner or later you will be replacing a broken gear box..even if yours does not have them get them..a $2 bolt or new gear box your choice.Just measure the bolt length and the shaft diameter not any shear bolt will due..the grooves on the bolt are meant to be the same size as the shaft diameter to insure shear at the shaft area that is under extreme pressure..Hope this helped..good luck.
Sep 29, 2014 | Garden
Blades disengage after mowing for a while on John deere x495
This could be a couple of things. Your pto clutch could be going bad. Or, if you loose charge from battery your pto will shut off as well. I would check volts across battery terminals, then start unit and raise rpms and note the change if any. If there is no change in rpms from stopped,idle, to high rpms you have a charging issue that would cause this problem. If charging system checks out your problem probably lies in pto clutch. Hope this helps,good luck!
Aug 10, 2013 | Garden
The tiller will not rotate. The PTO shaft on the tractor is spinning but the tiller will not move. The shaft coming out of the top of the tiller will not spin. There was also a burning smell with a...
Sounds as if you might have destroyed the gearbox or cooked the internal clutches or both....nothing to do but disassemble the gearbox to find out...you may have a broken gear tooth or teeth jamming the pinion...the FIX may be more expensive than the cost of a new tiller...call Tractor Supply to see if replacement parts are even available...sorry to be the bearer of such bad news... ;-(
Aug 11, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | King Kutter II Gear Driven Rotary Tiller...
I just got a 5' KK rotary tiller and the pto shaft fits onto the tractor just fine with the button lock. The other end doesn't want to slide all the way onto the tiller gearbox drive shaft. It only goes...
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Mar 10, 2010 | King Kutter II Gear Driven Rotary Tiller...
When I engage the PTO, the blades don't egage.
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
Sep 05, 2009 | Oregon Scientific Electric PTO Clutch for...
The blades stop and the 20 amp blowes on My YTH
Hello:
This Sounds like a Bad PTO.
The Following is a Basic File I Made for Checking the PTO (Blade Engagement). The Most Common Cause for this Problem is the PTO Ground. A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO. Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire. Clean the PTO Ground and All the Connections for the PTO Wiring Harness. If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
