Question about ASUS Computers & Internet
IM LOCKED OUT OF MY ASUS X501A
I DONT REMEMBER THE PASSWORDS FOR MY ASUS LAPTOP IVE TRIED SAFEMODE BUT IT WONT GO INTO SAFE MODE AND IVE DOWNLOADED WINDOWS PASSWORD RECOVERY BUT WHEN I TRIED TO USE IT IT TOLD ME THAT THE FLASHDRIVE I WAS USING WAS NOT A RECOVERY DISK HELP
emmbritech
  • 5 Answers
SOURCE: My Toshiba A205 S4777 won't start up and I can't use the recovery media to fix it.
Try flashing the bios by pulling the chord out attached to the "watch" battery.
Posted on Oct 13, 2008
  • 39 Answers
SOURCE: laptop freezes at windows login screen
If it's not a hardware problem, then you can salvage this computer by installing Linux on it. Mandriva 2009.0 works fine
on a T42 Thinkpad, and it's not that difficult a transition from Windows.
Posted on Mar 04, 2009
  • 63 Answers
SOURCE: i forgot my user login password
boot in safe mode by pressing f8 while starting up the pc.
  • 1. Go to your start button, select “Command Prompt” from the “Accessories” list.
  • 2. Type in “control userpasswords2” and press “Enter”. This command will launch the Windows 2000 User Accounts application.
  • 3. Go to the “Users tab” and check the box labeled “Users Must Enter a User Name and Password to Use This Computer”, then click “Ok”.
another way, is look for password resetter on the web.
Posted on Apr 01, 2009
pcj141414
  • 62 Answers
SOURCE: I forgot my password. I have bought a recovery
Sounds like your computer is protect with a BIOS password. A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. That's why the CDROM has been disabled and you can not run the recovery disk.
As a computer enthusiast, it is possible to reset the BIOS password but could be potential fatal to your notebook if you don't know what your doing.
Here is a method to bypass or remove a BIOS password.
Note: Make sure you are working in a static free environment before opening up your computer.
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery.
If you pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password.
Open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture above.
There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
The computer must not be able to get power from anywhere for this to work so make sure its unplugged from everything.
Take out the CMOS battery and wait 10 - 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto "Load BIOS Defaults" in BIOS and save the changes to fix them.
Enjoy, Have Fun and Don't Stress.
Posted on Dec 30, 2010
  • 14 Answers
SOURCE: forgot asus laptop password Windows vista
To reset your ASUS laptop Windows login password, I think you can try this password recovery software, fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. You can do it on your own, no need to send it to a computer shop. Regards.
Posted on Nov 17, 2011
ASUS X501A Locked (not bios, HDD or Windows)
Can you tell more detail about your situation? As you mention that you seem cannot be able to switch on your laptop. Or you can switch it on and in which status?
Dec 06, 2013 | Asus Systems Asus X501A Notebook
I have a ASUS x501A notebook and when i upgraded to windows 8.1 after restart it goes up to the logon screen where it says welcome Bobby and that circle keeps turning and then after that a bright black...
When you reboot the machine, keep pressing F8. this should give you a menu to boot into safe mode. when in safe mode you should have an option on the charms bar on the right to refresh your pc which will restore it to previous settings without losing your data.
Oct 26, 2013 | Asus Systems Asus X501A Notebook
Sylvania netbook synet07526 - - - cant remember my password. how can i reset the system? have tried holding down the reset button multiple seconds but the reboot does nothing but come to the password...
Resetting password & user name on Windows: b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Sep 24, 2011 | Sylvania G-Netbook
Im trying to restore factory settings. I cant seem to get the "press 0" trick to work. I cant even get the F2 or F12 to work. It just goes straight to the password screen. Of which I dont...
Resetting password user name & password: b> *Start your computer
Sep 18, 2011 | Toshiba Satellite Pro M10 Notebook
MY PC STARTED UP OK, AND I HAVE A PARENT ACCOUNT AND A KIDS ACCOUNT.I HAVE SINCE FOUND OUT MY 5 YR OLD HAS PUT HIS OWN LITTLE WORDS IN BOTH ACCOUNTS FOR THE PASSWORD.HE DOESNT UNDERSTAND.IVE TRIED TO GO...
Try it...
Restart the laptop and press F8 continuosly,, then you will find the "SAFE MODE" option. Select the "SAFEMODE" then press enter.. Then you will find the "Administrator" user account. Try to login to that Administrator . Try the password as administrator or admin or with none. Try it...
Jun 18, 2011 | Computers & Internet
My computer when i turn it on wont boot up with out password? i dont remember ever setting one . now im locked out please help and yes my laptop is regester'd on web site
Reboot your computer in safe mode. Then, click run, start, and key-in "control userpasswords2", Next, click reset password and change the password and confirm. Reboot and your ready to go.
Sep 11, 2010 | Toshiba Satellite L305-S5921 Notebook
Locked out of laptop :(
If You just installed Ubuntu and forgot what password you selected during the installation process or one of your friend gave you ubuntu computer without giving username and password.This tutorial will help you to recover username and password
1) Turn on your computer, and as soon as you the Press Esc to enter grub message, press the escape key.
2) Select the option that says (recovery mode).
3) Your PC will boot into a shell. Once you get a command prompt, type “passwd username” where the username is your username. If you can’t remember your username, then you can type “ls /home” which should bring it up.
4) Enter a new password when prompted, and again when prompted again Type “shutdown -r now” to reboot your system,
That’s it. You should now be able to login with your new password.
Jun 02, 2009 | IBM ThinkPad T20 2647 Notebook
Forgot my windows vista login password
Try to login to safe mode with administrator login and change the password for your user account.
There is no way to bypass user security otherwise in Windows Vista.
Mar 23, 2009 | Acer Aspire 5630 Notebook
My admin account wont work
Did you downloaded that on a virus-free website like www.download.com? And one more thing, when you mean "I can't use my admin account", do you mean windows is telling you that the password you enter is wrong? If that's the case try booting into safe mode (by pressing F8 before the XP Logo). By default, XP have a built-in "Administrator" account name & the password is blank. You should be able to login with that & try to change your password on your account on the user accounts setting on control panel.
Hope this helps.
Aug 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
656 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
