My motherboard has jumpers on it my grandchild
My motherboard has jumpers on it my grandchild removed them and i am looking for the proper install for them
s1692d duel pentium 2 440lx tyan computer corp.
please e-mail me with install specs if available.
thank you
normand marquis
norm@marquisandassociates.com
203-573-0302
  • Mahmoudatef5 May 03, 2009
    the same problem
  • 4,806 Answers
Hi there.
Tyan provide motherboard settings and specs for that model mobo here >>>>>>>>
http://stason.org/TULARC/pc/motherboards/T/TYAN-COMPUTER-CORPORATION-Pentium-II-S1692D.html
Good luck and thanks for using Fixya!!
Posted on Mar 12, 2009
Please clear cmos system no display after overclocking
You can clean Cmos By Using the Motherboard Jumper method
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
if you think this was helpful?then pls.rate and if further question about it,i'm always open to help..goodluck and godbless
Feb 22, 2011 | Biostar G31-M7 TE Motherboard
I am facing a problem to install my XFX Radeon HD 4350 1GB graphics card. My PC has a intel DG31PR with core 2 duo and 3 gb ddr2 RAM. the CPU starts but there is no visual on my ACER monitor. I have...
It sounds like you need to change a BIOS setting. I don't have this MoBo, but on others there is a toggle to make the integrated graphics primary or secondary. You would need to change it to secondary. On this card this should happen automatically - so check BIOS settings and that your new card is properly seated in the slot.
From http://www.intel.com/support/motherboards/desktop/sb/cs-022225.htm
Installing External Graphics Cards
If you want to install a 3rd party external graphics card instead of using the onboard graphics, follow these steps:
  1. Install the 3rd party external graphics card, following the installation instructions that come with the card.
  2. Integrated graphics is automatically turned off.
Jan 10, 2011 | Intel DG31PR Motherboard
BIOS PASS WORD LOST
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Jun 26, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
A password bois in thinkpad t60 et merci
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Apr 24, 2010 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
How to reset bios password on inspiron 1150
Apr 18, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
When i start my computer boot screen appears every time.
may be you cmos battery is weak just remove the battery and install new battery and also make sure jumper position is proper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Intel D945GCCR Motherboard
How to break bios password
remove CMOS battery for 1 minute then try to install it back
Jun 08, 2009 | Intel D945GCCR Motherboard
How can i remove bios password
disconnect your laptop battery and, bios battery on the mother board wait 10 minutes plug the bios battery back in then; reboot without installing the laptop battery: your passwords will be removed
May 20, 2009 | Computers & Internet
845 GVSR MB
If your RAM was bad, it should beep with it installed.  Chances are, if your RAM is compatible with your motherboard, then you need to reset your BIOS.  You may want to check your motherboard manual for instructions, but typically it goes like this: unplug the power cord, remove the small round battery from the motherboard, find the proper jumper (little plastic piece of metal prongs) and move it to the proper prongs to reset the CMOS (BIOS). Then, move the jumper back into the proper position, put the battery back in, plug the power cord back in and reboot PC.  You should be prompted then with a CMOS reset screen.  Some motherboards have alternative methods to resetting the BIOS, so if that does not work, then you will need to consult the manual.  If this does not fix your problem, please let me know what type of RAM you are using, and whether or not it is newly installed, or if it is the same RAM you have been using. Hope this helps :)
Jan 01, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
No power up
Check the cmos reset jumper and check the case switch then.. I would look on the jumper positions for the case and short the PWR SW to see if the case switch is messed up. Then make sure to check all the peripherals.. remove them and re-install... make sure the memory is set in properly. Try to boot without any drives plugged in to see if any drives might be bad.
May 02, 2008 | ASUS P5N-E SLI Motherboard
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
