Question about Dell Inspiron B130 Notebook
Firewall is now password protected
Somehow my granddaughter password protected something in her laptop and now the firewall is password protected and we can not release it from that mode.therefore we can not get on the internet or do anything except turn the computer on.
  • blancastrega Mar 13, 2009
    this is a dell inspiron b130 and I am in the colonies...or United States...
  • Daniel Florin
    Daniel Florin May 11, 2010
    Hi if you are in DUBLIN i can Help you Free of charge, 0860808037.What make it is the Pc/laptop.
Turn off window 7 firewall
Open Windows Firewall by clicking the Start button Picture of the Start button, and then click Control Panel. Write firewall in the search box, and then click Windows Firewall.
Click Turn Windows Firewall on or off. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Windows Firewall off (not recommended) under each network location that you do not want to protect, and then click OK.
Jul 03, 2014 | Microsoft Computers & Internet
Tip
How to protect from Keylogger
Keyloggers also known as key Stroke recorders are the softwares that can record the key strokes.These are Used in phishing websites to steal your username and password.These keylogger can also be installed on a computer and they can send usernames and passwords using your Internet connection.You can protect yourself using this tips & tricks.<br /><br />1.Enable Your Firewall:-<br /><br />Firewalls donot stop the keyloggers from entering into your PC But hey can help in stopping the keyloggers from sending your information.It is always recommended that you install a good firewall software to protect your computer from unauthorized access.By default Microsoft windows firewall is enabled.<br /><br />2.Use Good Antivirus Software And Avoid Downloading cracked Softwares:-<br /><br />Use good antivirus softwares like Norton,mcafee or use the free ones like Avg,Avast,Avira.They certainly provide a lot of protection against keylogger.Also avoid using torrents as much as you can because torrents is the hub of viruses and home of hackers.<br /><br />How to Foll Keyloggers<br /><br />If you believe that their is a keylogger in your system then you can do the following things to protect yourself<br /><br />1.Instead of typing your username and password using your keyboard type it using On Screen Keyboard.On Windows Platform it can be opened By typing osk in run. Or you can take it from Start-&gt;All Programes-&gt;Accessories-&gt;Accessibility-On screen keyboard<br /><br />2.Type 2-3 random characters in your password field and then select it using your mouse,Now type your real password.This will add the random characters in front of the password recorded by keylogger and the keylogger is fooled by you for sending wrong password.<br /><br />3.Keylogger runs in the background.Always check out for suspicious processes using task manger and end them.
on Mar 15, 2011 | Computers & Internet
Granddaughter fooled around and changed password and doesn't know what she changes it to ..ay way to fix it I am nt able to log in at all
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Sep 02, 2012 | Lenovo G460 Notebook
My Laptop cannot play DVD/RW CD
Hi arudgar ,
I would like to know if what is the model of your LAPTOP, so that i can help you with your problem.
Thanks.
Thank You for using Fixya.
Aug 31, 2011 | Computers & Internet
Hi im anthony and i had bought a laptop from a guy and it has k9 web protection on it and im tryn to get it took off can u pleasde help me
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website 2.Click "get K9 NOW" tab on the top-left 3.Fill out the information and your email. 4.Download the K9 Web protection software from the link included in the email and keep a copy of the license. 5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job. 6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab. 7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection. 8.Remove the contents of the folder but not the folder. 9.Run the K9 web protection setup/installer file which has the same version as the one you just delete 10.Provide the license and create your new password 11.Point the installation folder to the same folder you just empty the contents earlier on 12.Now you can have a re-installed K9 web protection with a password you know. How do you uninstall K9 web protection now? Use the new password you just created If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode" Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder) Click "Start"->"Run" and type "msconfig" Check the tab "Services" and tab "Startup" Un-check anything that is related to k9 If somehow this method is messed up, try to download K9 again to at least restore your previous installation. If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
Aug 24, 2011 | Dell Inspiron 1501 Notebook
I have same password problem on starting up my dell D430 and it's frustrating cause I needed to bye me new laptop. Again on dell D430 there is a lot of docs personal pictures and so on I would like to...
IF U FORGOT URPASSWORD THEN SEE HERE WELL DEAR IF U FORGOTUR PASSWORD WHEN U WANT TO LOGIN INTO WINDOW THEN RESTART UR COMPUTER PRESS F8GO INTO SAFE MODE JUST WAIT FOR A WHILE
AFTER ENTER ADMINISTRATER THEN GO To
CONTROL PANEL THEN
USERACCOUNT THEN
REMOVE OR WHT EVER U WANT TO DOO.OTHER METHOD============
Click on START -->RUN.
Type compmgmt.msc & press enter.
In the left pane, select COMPUTER MANAGEMENT--> SYSTEM TOOLS--> LOCALUSERS AND GROUPS--> USERS.
Then in the right pane, select the user name whose account you want to change.RIGHT CLICK and then click on SET PASSWORD from the pop-up menu.
Enter the new password. Click on OK.
There you have it. You have changed the user's password
Feb 26, 2011 | Computers & Internet
I have a dell latitude E5500 and my mate thought it was a good idea to change my password on the main screen and somehow forgot what he changed it to, so im now im stuck not being able to go on my own...
easy one just remove all power sources then find and remove the little battery inside rear of laptop leave it out for 30 minutes when you put it back and power up there will be no password protection ,, hardest part is locating little battery its like a watch battery maybe behind keyboard or the ram
Sep 25, 2010 | Dell Latitude E5500 Laptop
Trying to find a way to reset or bypass the HDD1 user password on my Toshiba A135-4527 laptop. It was reset somehow to something we do not remember. Hoping I do not have to replace the harddrive. Saw...
The hard drive password is set from the BIOS configuration where the hard drive was installed and you need to know the password to remove the existing password. You can only remove the password from that computer's BIOS and moving the hard drive to another omputer will not allow you to remove the password or access any data on that hard drive because the password is stored in the hard drive's firmware. This password protected hard drives prevents unauthorized access to the data on that hard disk.
Removing the BIOS battery will reset the BIOS but will not remove the password.
Some computers have been setup with Power On Passwords and/or hard drive passords and it is possible to hack/read the Power On Password that is stored on an EEPROM chip on the laptop, but it is not a simple process.
You will need to buy a new hard drive and now you also have a nice paper weight.
Feb 19, 2009 | Toshiba Satellite A135-S4527 Notebook
Help! forgotten password
Have you tried to reboot in safe mode and login as administrator with no password?
May 29, 2008 | Umax ActionBook 340T
Dell Inspiron B130 Notebook Logo
70 people viewed this question
Alun Cox
