Question about Baby Care
Copies come out with black over entire sheet of paper. How do I fix this full black coverage?
  • 56 Answers
SOURCE: km3035 prints out a black sheet of paper
Try to upgrade/reload print card firmware
Posted on Oct 31, 2007
s4u311
  • 813 Answers
SOURCE: copy and scanning problems
hi firend
remove ur printer driver & reinstall it if problem occers then chak the cardige if problem come the scanner lanse gone bad
u have to replace it
Posted on Apr 01, 2008
SOURCE: My copy machine will just print a totally black
Pull out your toner cartridge, push back the drum shutter and see if the drum is coated in toner. If so, it is defective. Replace it and it will be fine.
*please rate me ;)
Posted on Mar 21, 2009
SOURCE: Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Posted on Mar 26, 2009
canontech
  • 1219 Answers
SOURCE: COPIES PAPER BUT PRINTS BLANK SHEETS
You probably haveing poblems with laser shuter. call service
Posted on Feb 15, 2010
Have a hp laserjet pro 200 m251nw. Keeps getting paper jam message, but there isn't any paper jammed. Need a fix, please.
Lynne there may not be a full sheet of paper jammed, but a small piece could e under the sensor. get a can of compressed air and blow out the entire paper path.
good luck!
Sep 08, 2016 | HP Color LaserJet Pro 200 M251nw
When printing black dots appear chaotic, over the entire sheet of paper. What to do?
If the black dots appear on every sheet of paper it could be the fuser unit is wearing out or the drum unit. The way to check that is to stop a print half way through and remove the paper. If they are not there before the fuser unit but after it then it will be the fuser. Or if they are there before the fuser unit it will be the drum unit. If it they only appear specfic to one source then it is likely to be the source of the document. IE copying - check the optical area (scan glass etc). If on incoming Faxes it may well be the sender that has the problem and is just transmitting them to you. Hope this helps.
Sep 09, 2015 | Canon iRC2380i
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
Black stripe across copy
The orange roller is probably contaminated from toner that is sticking partly to the photodrum in the cartridge. That roller is likely made of silicone rubber (heatproof) that presses the paper against the fuser roller to 'fix' the toner to the sheet.
I suggest replacing the cartridge and cleaning whatever is accessible before you put the new cartridge in.
May 04, 2009 | Minolta Office Equipment & Supplies
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Baby Care Logo
747 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
