Question about Canon DR-7080C Flatbed Scanner
Canon DR7080C Scanner - top feeder not responding
I have a Canon DR7080C Scanner. Was working great until yesterday. Flatbed part of scanner working. Top feeder does not pick up paper and readout just says "Scanning..." Any ideas?
  • 490 Answers
Clean the rubber rollers with Isopropyl alcohol. Pls dont use solvents. Daily you need to wipe the scanner and rollers with a damp cloth for best performance.
S. Mohan. Chennai, India
Posted on Mar 16, 2009
Streaks on copies when original is fed through Imageclass MF 4694 top feeder; doesn't happen when on flatbed
There is dirt on the ADF glass. Normally to the left of the flat bed glass, there is a thin glass strip. Clean it with a damp cloth.
Aug 06, 2012 | Canon imageCLASS MF4690 Multifunction...
Just purchased canon canoscan 5600f today but can't get it to work. The MP Navigator EX2 on the desktop doesn't respond immediately and when it does it says not enough memory. Buttons on scanner don't...
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jun 18, 2010 | Canon CanoScan 5600F Flatbed Scanner
Scanner will not load from top feeder. Error says paper jam but no paper is jammed into the feeder.
the rollers may be broken, this would give the appearance of the paper jam to the printer
sorry not sure how to fix this one
Oct 09, 2009 | Visioneer 9450 Flatbed Scanner
My Canon 8400F worked yesterday and today it is not responding. I am getting an error message after the scanner determines what type of photo is to be scanned. It says: 1)Original may not be set...
First, make certain that the flatbed scanner lid is securely shut.
Second, unplug the power and USB cables from the rear of the scanner.
Third, deposit the Canon 8400F scanner in the nearest garbage receptacle where it belongs.
Hope this helps.
Jul 04, 2009 | Canon CanoScan 8400F Flatbed Scanner
Scanned Image is all black
Try uninstalling and reinstall the scanner again. Try on a different computer. If even after this the problem remains, may be the there is some hardware fault (failure of light) in the scanner. How is it in color?
S. Mohan
Apr 09, 2009 | Canon DR-1210C Scanner
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Fix scanner dr 7080c
We had the same problem and called a Canon technican to come out.
Open the lid, take the two screws on the left-hand side out, so you can remove the flatbed glass.
You will have to remove one or two metal plates to get the glass out. Be very careful with the glass!
Now you can get to the mirror part. You should be able to put it back into place.
Hopefully this helps!
Jan 13, 2009 | Canon DR-7080C Flatbed Scanner
Load Paper in Feeder Error Message
i had this problem b-4, sometimes you have to turn the printer on and off seceral times befor it works. if you go to your trouble shooting under printer problems you take like a survey to find the problem. was it on when there was a storm? sometimes that can cause an error in the system to. sometimes you just have to repeat over and over w/ turning the computer and printer on and off several times until it works. good luck!!!
Jun 24, 2008 | Canon DR-3080CII Path-Through Flatbed...
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
Canon DR-7080C Flatbed Scanner Logo
258 people viewed this question
old marine
old marine
