Fujiaire f6 fault code unit turns off and won't restart
Unit will not run unless power is turned off at wall. Then it starts and outside unit does not start and the unit turns off after a few minutes with error code f6
5 Suggested Answers
  • 140 Answers
SOURCE: air conditioner not geting cool
Hello, It sounds to me like your low on freon/refrigerant. You'll need to have someone test the pressures for you.
Posted on Jan 24, 2009
  • 400 Answers
SOURCE: LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Posted on Mar 05, 2009
  • 5 Answers
SOURCE: I have a Braemar LCB450-G
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Posted on Nov 26, 2010
  • 3 Answers
SOURCE: c6 error code on LG art cool
Condenser fan windings are rooted. No capacitor due to multi speed. Replace condenser fan motor they just clip on pcb.
Posted on Feb 08, 2011
F6 error code on Frigidaire split unit ac, model FSC12CM6J/FSE12CM6J. Solution says to check fuse? Where is this located?
It seems like the indoor fan is not running. Quite a few split systems have a fuse on the indoor board. It will require stripping off the outer cover of the indoor unit and removal of the electronic box cover. The indoor board is in there. The fuse may be replaceable or it may be a type that is soldered on which makes it virtually non replaceable. ( A new indoor board will be required) Make sure all power is turned off or disconnected before you do anything. Another possibility is the fan motor start capacitor has failed. Try this first before stripping the unit. When the unit is turned on and the outdoor unit has started, give the indoor fan barrel a flick with your finger to start it spinning, if it keeps spinning and the error doesn't appear, it would indicate that the fan motor start capacitor has failed. The capacitors on indoor units are normally small black square boxes with 2 terminals on it. These capacitors are mounted inside or close to where the indoor electronic box is. Again, make sure all power is disconnected or turned off at the meter box before you do any disassembly.
Apr 09, 2014 | Frigidaire Heating & Cooling
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Ac compressor will not start
Hello, sounds like a faulty capacitor. Check the capacitor to see if it is puffed up at the terminals. It will be located inside the outside unit and looks like like a can that is oval or round.
Jun 17, 2012 | Goodman Heating & Cooling
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
Why isn't my A/C unit fan not running but my indoor fan is ?
The outside fan, as you called it. will not run unless the compressor (which is your outside unit) starts up. Obviously, there is a problem with the compressor. It could be something very minor like a blown fuse or tripped circuit breaker or even a loose wire in your wall thermostat. Or a shorted out wall thermostat.
Those are the things you need to start Troubleshooting (looking at) first.
Hope this helped you get started in resolving the problem.
Jun 19, 2011 | Heating & Cooling
Outside unit won't come on. Drain pas appears dry/.
if nothing comes on (on the outside unit) when you turn on AC (and the inside unit runs ok) I would check the fuses and/or the breaker for the outside unit. I would suspect a fuse blown or a breaker tripped. It's also possible that your 'low voltage' (24V) thermostat wire has been cut (by lawn mower) or chewed into (by dog). If the problem is the low voltage wire you can easily splice it back together - just be sure all power is off.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
Split unit aicon fujiaire appear e3 message
I have a Fujiaire split unit(wall type). I have this problem quite frequently, an error code E04 display, Try to look at the operating manual, it does not specify the problem, I check the compressor motor winding, the amount of F22 charge and clean the outdoor and indoor unit. Wonder why put an Error code when there is nothing on the troubleshooting list. But whenever the authorize repair man come for servicing, he could not tell me. Does anyone has a solution?????
May 26, 2011 | Heating & Cooling
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
