EPEWF100077 COMPUTER PROBLEM...
  • 38 Answers
Dear Oderdene,
PLEASE STATE THE PROBLEM!!! The more information you provide, the easier it is for someone to give you an answer: computer make & model;Operating System; outline the fault/problem with as much detail as possible. Kind regards. GBU! - Bruce.
Posted on Apr 30, 2013
Do not know how to connect power supply
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Unplug all electronic cords connected to the computer.
At no time during the installation should any cords be connected to the computer.
Remove the screws holding the computer cover case, and remove the cover case.
Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case.
Unplug the power cables from the internal devices connected to it.
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember--write it down if you need to--what devices will need reconnecting to the new power supply when you finish the installation.
Unscrew the power supply from the inside of the computer case and remove it. Check the original power supply's red voltage switch for the correct setting.
It should read 120 or 240 if you live within the United States.
Confirm this setting as the correct voltage setting for your power outlets.
Make sure your new power supply gets set to the correct voltage setting before you install it.
If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer.
Return the new power supply and buy one that is compatible with the voltage requirements.
Install the new power supply, reattach the screws that will hold it in the proper place inside the computer.
Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply.
Make sure all of these connections are firmly in place before you turn the computer back on.
Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet.
Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices.
Turn the computer on and observe the performance of the computer without touching anything inside.
Do all the computer fans function normally?
Does the computer operate as well as or better than before?
If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case.
Then reattach the power cords and peripheral cables and begin using the computer.
Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside.
Make sure that you connected all the correct power cables inside the computer securely and did not miss any.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation
http://www.youtube.com/watch?v=xvClS_M-09o&feature=watch_response_rev
watch video
hope this helps
Oct 10, 2012 | Computers & Internet
Tip
Computer Running Slow?  The guaranteed way to speed up your computer!
<span>Computer running slow? Nothing is more frustrating than a slow computer. Speed up your computer now with our proven computer optimization service. As a leading Microsoft&reg; Partner in the online computer repair industry we have access to the latest tools and resources from Microsoft&reg; and others to </span><span>speed up computer</span><span>, </span><span>computer running slow</span><span>, <a href="http://www.mycomputerexpert.com/speed-slow-computer.php">fix slow computer</a> and Netbooks running Windows 7, Vista and XP.</span>
on Jun 26, 2011 | Computers & Internet
Tip
Connect your home computer from Remote location.
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources).
You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
Follow the given steps to configure your computer to connect remote computer: To use this feature, you will need to be logged into your computer with administrative rights.
-To perform this task, first make sure your both computers are connected to the internet.
-First you have to configure the host computer that allows the users to connect it remotely. On the host computer, right click on "My computer" and click on Properties option.Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
-Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
-Now make a connection on remote or client computer, click on Start button, go to All Programs> Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
-If your username and password is correct then a remote desktop windows will appear.
Good luck.
on Apr 15, 2010 | Computers & Internet
Tip
How Often should i clean my pc?
Where is computer located? In a home environment In a clean office environment In construction / industry environment In school environment Computer environment Have cat / dog in same building as computer Smoke in same building as computer Smoke next to computer Computer is on floor Room that the computer is in has carpet Eat and/or drink by computer Who uses it? Adult (18 and older) Young adults (ages 10-18) use computer Pre-teen (younger than 10) use computer More than one person uses computer
Based off what has been checked above you should be cleaning your computer every months.
on Mar 13, 2010 | Computers & Internet
Tip
Computer Repair Services
Computer repair includes software and hardware repair. Hardware repair is needed when any part of the computer is not functioning as expected. Software repair is required when any software program is not executing properly.
Need of computer repair
Computer repair is needed for making your computer function properly. Your computer will function properly if all its parts are working properly. Some of the issues for which you require computer repair are as follows:
• Computer automatically shuts down
• Computer takes much time in launching applications
• Computer system crashes or locks up
• Blue screen error
• Computer makes beeping sound when switched on
The reason for most of the computer issues is the lack of maintenance. For maintaining your computer and optimizing its performance, you have to update software regularly, clean registry, empty cache files and many others.
In case, you have the knowledge about how to repair your computer, you can perform it yourself. But if you do not have any knowledge in this field, then you can contact a computer support technician.
Computer repair technician is a person who will repair your computer either through online or on-site. Online computer repair is preferred in case your computer needs software repair. If you want to go for online computer repair, all you need to have is an Internet connection. Online computer repair saves your from the pain of taking your computer to some technical services center or inviting some technician at your own residence.
These days most of the companies offering online computer repair adopt the method of remote desktop connection. Technician will access your computer with the use of software made for remote desktop connection. But you have to give him permission for doing so. After getting permission, he will diagnose your problem and after that resolve it. Technician will install, reinstall or uninstall any software, or modify some of the settings for resolving issues.
In case of hardware repair, you have to call a technician in your premises. Technician will diagnose all of your peripheral devices, in case of any faulty one, he will replace that one. He will also update drivers of peripheral devices.
So, it can be said that computer repair is required when your computer is not functioning as expected.
on Feb 04, 2010 | Computers & Internet
Transfering pictures to computer
Downloaded disc to computer, computer tells connection can not be astablished. When I check the computer evrythings in there. I also took everything out and reloaded it. Computer isn't old and I have window xp. Help me please.
Feb 23, 2008 | Canon PowerShot A560 Digital Camera
Tip
How to connect your home computer from Remote location?
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
my_computer_properties.jpg Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
remote_desktop.gif Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
remote_dialogbox.jpg Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
remote_desktop_connection.jpg If your username and password is correct then a remote desktop windows will appear.
on Dec 03, 2009 | Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
