Question about Husky Electric Portable Air Compressor: 30-Gallon C301H
COMPRESSOR WILL START UP AND SHUT OFF WHEN FULL AND RESTART 2 ,3 TIMES THEN IT WILL NOT RESTATRT WHEN EMPTY HAVE TO WAIT 45 MIN TO ONE HOUR IT WILL FILL UP AND ONES IT OUT OF AIR WILL NOT RES START F
MY COMPRESSOR IS A HUSKY 33 GALLON MODEL # F3S33VWD /516-051 ELECTRIC 120V IT IS RUN DIRECTLY FOR ELECTRIC OUT LET NO EXTENCION THSI STARTED ABOUT 2 MONTHS AGO I BOUGTH IT 0N 9/3/2012 CAN YOU HELP ME ???
Why it shut off at 50 psi
Posted on Jun 18, 2014
2 Suggested Answers
  • 33 Answers
SOURCE: motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Posted on Sep 03, 2012
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
1994 toyota camry
Any coolant in the system?
Feb 03, 2014 | Computers & Internet
Frigidaire was laid on its side for 15 min and turned on afterwards. Now it wont cool
Unplug the refrigerator for about 12 hours to allow the oil to seep back to the compressor. When you plug the power back in if you don't hear the compressor restart then wait longer. Just don't leave it plugged in to wait for the oil to settle hoping it will restart because that will be ******* the start relay and other components, Sea Breeze
Sep 23, 2013 | Frigidaire Refrigerators
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Aug 26, 2011 | Garden
Hotpoint future freezer red light stays on and motor makes buzz noise every few mins but only for about two seconds.
Hi and welcome to FixYa, I am Kelly. Your hearing the compressor Thermal overload cycle every few minutes for no more than 45 seconds. The compressor is not starting at all or it is not cycling from the start winding to the run winding so the KliXon thermal overload is tripping. That switching of windings is done by the PTC relay mounted on the side of the compressor. The Compresor part number is EMY32CLC. PTC relays can be found here:
http://www.europart.co.uk/s.nl/sc.2/category.690082/.f You will have to match your relay to the image.
I would recommend using the phone locally to purchase the relay AFTER performing the following.
POWER OFF / Unplugged WAIT 30 minutes for the compressor to cool and the coolant pressures to stabilize. After 30 minutes plug in the unit and see if the compressor starts.
IF after 30 minutes the compressor does not restart....
1. Read the pins of the compressor to the case of the compressor. No grounds allowed.
2. Read pin 1 to pin 2 (on 2 pin compressor) you should read resistance.
3. If you have a 3 pin compressor only 2 of the 3 pins will read to each other at any given time. One for start winding and one for run winding with 3rd pin being common.
A locked compressor rotor/armature will also cause the compressor not to start. A locked rotor requires compressor replacement. (Fingers crossed lets hope that the rotor is not locked!)
Hopefully your unit will restart. A momentary loss of power will cause a compressor to hot cycle and not restart. All it takes is about a 8 second power loss to put the compressor into this no start frenzy. Do the 30 min no power thing and see what happens. (maybe save your self lots of money.)
Thanks for choosing FixYa,
Kelly
Dec 05, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
2002 VW Beetle 1.9 TDI Air Conditioner
the resistance should have a reading in the compressor drive clutch
if it has a 0 reading it has failed
no compressor drive =no cooling
Mar 11, 2017 | Volkswagen New Beetle Cars & Trucks
'04 volusia still shutting down
I would recomend checking to be sure the fuel and vacum lines n the tank are installed correctly, Open the fuel filler and start the bike and see if it has any change on the problem, if so you have a vacum issue.
Mar 10, 2009 | 2004 Suzuki VL 800 Volusia
I hv a colemanpowermate 5000/6250w generator- won't stay running
Hi, Please understand that this type of troubleshooting is hard without seeing it but doesn't sound like a fuel issue at all. This genset does have other sensors that will shut it down like low oil and high temperature. Most likely oil from your description. You also don't say what load it is carrying, could you be plugged into something that cycles off and on and when it cycles on the genset shuts down from the overload? If you think this might be the case, disconnect everything and power up a few at a time especially things that cycle on and off like refrigerators, heaters, stoves. Good Luck!
Jan 30, 2009 | Coleman Powermate Premium Plus 6250W...
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Husky Electric Portable Air Compressor: 30-Gallon C301H Logo
528 people viewed this question
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
