Aeg lavamat 62600
Failurer e60
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
buffalonyman
  • 1865 Answers
SOURCE: AEG 62600 Will not fill. Hose from tap is clear. Help
Try filling with hot and cold water, the water valve solenoid may have failed.
Posted on Jun 01, 2009
SOURCE: My AEG Lavamat 62810 keeps coming up with an error
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Posted on Aug 12, 2010
  • 6277 Answers
SOURCE: i need manual instruction for
You will need to type into your search engine 'aeg washer manual' and you should be presented with a number of sources from which you can either download a manual for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 11, 2011
  • 174 Answers
SOURCE: My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
E60 relates to heating of the water. either problem with the heater or wiring back toto the main electronic/ or faulty electronic. check the heater first.
Posted on Aug 04, 2012
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
Feb 28, 2015 | AEG Washing Machines
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
Lavamat 62600 not heating
Sounds like the heating problem is an element that burned out.
Aug 27, 2014 | AEG Washing Machines
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
Jul 25, 2012 | AEG Washing Machines
I need manual instruction for AEG Oko LAVAMAT 62600 (product code: 92410419)
Good luck,
John C
Feb 11, 2011 | Washing Machines
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
Aug 06, 2010 | AEG Washing Machines
Jun 01, 2009 | AEG Washing Machines
Error code e60
Jul 07, 2008 | Zanussi ZWF1440 Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
