Question about Garmin StreetPilot 7200 GPS Receiver
Garmin basemap I want to download the latest basemap
3 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: transfer general basemap from trip&waypoint manager to garmin legend cx
and what happens exactly when you try this?
Posted on May 08, 2008
pabloloco
  • 2335 Answers
SOURCE: no basemap n garmin nuvi
I can help you reset and fix your Garmin Nuvi 265WT.
A message about not finding any maps is an indication that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Posted on Apr 19, 2010
Unfortunately deleted the maps suppled withe the device.Hve obtained the basemap and sum file on dics from garmin and have loaded it to the device however the maps are not showing up.Have downloaded...
The base map will just give you major highways. You are missing the gmapprom.img file which supplies all city streets. The sum file is not used and is only a checksum file to insure that the basemap was downloaded without errors. The map file, depending on year can be anywhere from 1 to 2GB in size and too large to be sent by email. In addition, you will need an unlock code file to activate the map on your unit. More info can be found here:
http://www.sharc.net/gps_lost_map.htm
Oct 23, 2013 | Garmin nuvi 205 GPS Receiver
When reinstalling the maps to the unit, use the program Map Install from garmin. If you did and still cant find your maps, call garmin back and have them remotely access your PC. They will be able to fix your issue.
Hope this helps!
Feb 12, 2011 | Garmin GPSMAP 62s GPS Receiver
No basemap n garmin nuvi
I hope that helps.
Mar 21, 2010 | Garmin Nuvi 265W GPS Receiver
I have a Garmin GPSmap76 and did the update from garmin and it took my basemape off so what can I do to get it back? It updated me from 2.0 to 4.0 can you help me?
That sounds strange. I wasn't aware that you could remove the basemap. Anyway, if you want to put the unit back to factory specs, as when you received it new, you may want to consider doing a Master Reset. Be aware that you will loose all user input - that means settings which you have entered, waypoints, routes, and tracks. Make sure you have noted your settings and backed up your data before doing the master reset. I don't know if it will restore a basemap or not, but it's for sure, it will restore everything else to "original". Again, I've never hear of loosing the basemap, are you sure it's gone? You might ought to call Garmin about that 1-800-800-1020.................good luck
Nov 30, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin nuvi 610 No Maps
Do a hard reset on the device. Download Garmin Express and install it to your PC. Connect your device to your PC. Garmin Express will identify it and allow you to install all the maps and software that the device has a subscription to.
May 01, 2017 | Garmin Nuvi 610 GPS Receiver
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
Spell state on GArmin Nuvi 350
Go into "Map Info" and make sure that check box is checked, so the system can "use" that map.
Sep 15, 2007 | GPS
Garmin StreetPilot 7200 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
