Question about Dryers
Whirpool electric dryer model ler4634eqo what year was made
What year was made my electric dryer whirpool model ler4634eqo
  • 4 Answers
SOURCE: Dryer tumbler will not turn
Does it turn on and run with out the drum turning around. if so you most likely have a broken belt, if just the light comes on and nothing else happens your thermal fuse is most likely bad.
Posted on Feb 27, 2008
mikedurland
  • 481 Answers
SOURCE: whirpool dryer
once you take the element casing out of the dryer then you will see a screw at the very bottom of the casing where the element goes in. usually a 5/16 hex head screw.1933c22.jpg
Posted on Jul 07, 2008
rickzilla
  • 706 Answers
SOURCE: whirpool electric dryer: heat turns on but no rotation
Your problem could be as simple as a broken drive belt.. or an overtemp switch.... If you've never replaced the drive belt.. then that is in all probability your problem.. If you reach inside the dryer drum and try to rotate it.. does it offer any resistance like it is turning a motor pulley system or is it free to rotate with very little resistance ( would suggest the belt broke).. If the cost to repair exceeds the cost to replace then you'd be better off replacing.. However ..if it is just a drive belt.. then I would just replace that.. Hope that helps...
Posted on Aug 24, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: how to change a belt on whirlpool dryer
Check out this page for good information on changing the belt. Good luck with your repair!
Posted on Mar 02, 2010
heatman101
  • 43501 Answers
SOURCE: GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 29, 2010
I have a ler4634eqo and it runs but it stopped heating up and drying the clothes. It still blows air just cold air.
check circuit breaker heat is on seperate circuit may run with one circuit then check continuity on element,then limit switches, then timer
Feb 11, 2013 | Whirlpool LER4634J Electric Dryer
I HAVE A WHIRPOOL DRYER MODEL LEQ8858JQ1, AND IT TAKES TWO DRY CYCLES TO DRY MY CLOTH, DO YOU KNOW WHY, IT IT THE HEATING ELEMENT THAT NEEDS TO BE REPLACED OR SHOULD I CHECK SOMEWHERE ELSE???
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 26, 2011 | Whirlpool LER5636P Electric Dryer
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
How to change a belt on whirlpool dryer Model LER4634EQO
Mar 01, 2010 | Whirlpool LER4634J Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
I am needing to buy a heating element for my dryer (model # LER4634EQO) what # do I look for when buying element?
you use the model number inside the door,this is your part number,you can go to seras .com(parts)and order whatever you need-mike
Jan 29, 2010 | Dryers
Need to get to belt on my whirpool dryer
TAKE FRONT OF DRYER OFF PLACE BELT OVER TUB @ THEN OVER THE PULLEYS MAKING A FIGURE 8 LET ME KNOW IF YOU HAVE ANY PROBLEMS
Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top Dryers Experts
