Question about Audiovox D1812 Portable DVD Player
Repacement battery for D1812
Replacement battery?
Audoviox D1812 wont load dvd..
try to manually clean the lens of the player.open the cover and using a cotton buds moistened with an alcohol,gently wipe the lens to remove the dust accumulation.be sure to unplug the unit before cleaning.
Jun 06, 2012 | Audiovox Televison & Video
Battery is not charging
Check the voltage and currrent factor of the battery charging circuit. Use a multimeter in voltage during charging and in series to the battery using a jumper to see the current to the battery. If the charge voltage currrent is good then the battery is faulty , if not the charging circuit must be checked.
May 02, 2011 | Audiovox D1812 Portable DVD Player
Will not open lens starts to move then turns off repaced batteries still will not open
I have the same problem (lens starts to move then turns off repaced batteries still will not open) with a DMC-FX36, which is a model that cannot be repaired or replaced in the US because I bought it in the Hong Kong airport. Please let me know if you find a solution, and I'll do the same for you. Brot Coburn, bcoburn@wyoming.com
Jan 13, 2010 | Polaroid i1035 Digital Camera
I was given a free unit and it didn't come with an owner's manual...I need one!
here you go you need to register but it is free
http://portablemedia.manualsonline.com/manuals/mfg/audiovox/d1812.html?s=fpw
May 12, 2009 | Audiovox D1812 Portable DVD Player
Audiovox D1812 disc loads & plays but VERY dim screen
Sounds like the backlight isn't working, could be the flourescent tube or the inverter that powers it. At least those are the likely suspects in other LCD monitors that have similar problems.
Apr 01, 2008 | Audiovox D1812 Portable DVD Player
Audiovox D1812 Portable DVD Player Logo
59 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
