Question about Garden
1999 polaris sportsman will run a little while and then will not crank back up until next day
  • 7,482 Answers
Hi Marty
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 27, 2013
SOURCE: 2001 Polaris sportsman 500 magnum 4x4, speedo dont work
I'm not sure but it might be the sensor on the right front wheel disk
Posted on Sep 05, 2009
seanpwright
  • 2030 Answers
SOURCE: polaris 500 sportsman awd not working
the usual problem with those is either the switch itself or the magnetic hubs at the front wheels
The factory service manual will tell you how to check both
Posted on Jan 14, 2010
SOURCE: 03 Polaris sportsman 700 4x4 will not Disengage
I KNOW THAT IF YOU HAVENT CHANGED THE HUB OIL IN A WHILE THAT IT GETS DIRTY AND GETS STUCK IN 4-WHEEL
Posted on Jan 25, 2010
SOURCE: 2004 polaris sportsman 700, shuts off while riding.
I have a 2004 700 carb that shut off while riding and then would start up 3-5 minutes later after many nights working on it Ifinally figured it out no help from any dealer. There are 2 circuit breakers under the front rack mine were very rusted, Replaced both never had the problem again. My situation was always only when the lights were on.
Hope this helps
Posted on Apr 11, 2010
SOURCE: Service manual for a 2006 500 Polaris Sportsman HO
I have a 2006 Sportstman 500HO ATV, EFI. Sometimes it will run 100% correct, other times it will start, idle fine but then when giving it throttle will will start to surge almost like it's hitting a rev limited. Sometimes it will backfire and stall. I already replaced fuel filter, flushed the fuel lines and gave it fresh gas and installed a new spark plug, but no good. I also checked the throttle switch and it's not making contact to stall it. I download the service manaul and tested each sensor and they tested fine which is probablt why I get no check engine light.
This ATV is mainly used to plow snow in my driveway, no salt. It's used around my property but very lightly. It's still as clean as it was when I bought it and it doesn't have but about 40 hours on it.
Polaris 500 HO EFI 4x4 ATV: Vin# 4XAMH50A56B707664 purchased 6-8-2006
gtopercy@comcast.net
Posted on Jul 15, 2010
2013 sportsman 500 gas running out the carburetor bowl from bottom. plastic tube to the ground. is the needle seat stuck?
Hi, Christopher and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2012 500 ho leaking gas from carb overflow tube
Polaris fuel leak repair
Polaris 2007 Sportsman 500 EF Service Manual
2013 Polaris SPORTSMAN 500 HO A13MH50AJ AQ AX AZ OEM Parts
Polaris Sportsman 500 HO Owner Manual
Jan 15, 2017 | GAS Motorcycles
NO ELETRCAL POWER, WONT START
First check fuses and switchs. You can get a wiring diagram at Ronnie's.com
Jul 24, 2017 | Polaris 2007 Sportsman 500 EFI
I have a 2004 polaris sportsman 500 when it gets hot it cuts off and back fires
Does the cooling fan ever run when the engine is hot? If not, you may have a problem with the fan thermostat.
For the record, spray carburetor cleaner does no good if it's sprayed on the outside of the carburetor with the engine running. That's not what it's for.
Jul 29, 2014 | Polaris 2004 Sportsman 500 H.O
sounds like the coil is weak or the electronic spark box is goin fuel filter been changed ?right gap on the Plugs? need more imfo on it to do more thks
Idling Issue with Sportsman 600
Check the EGR valve.
Jan 03, 2014 | Polaris ATV
I HAVE A 1999 POLARIS 335 SPORTSMAN STARTS FINE WHEN I TRY TO ACCELERATE THE QUAD BOGS FEELS LIKE ITS GOING TO STALL BUT THEN GOES BUT NOT AT FULL POWER AFTER RELEASING GAS THERE IS A LOUD BACKFIRE ...
carbon on the plugs indicates flooding
the backfire indicates fuel being ignited in the exhaust
have the carby /fuel system professionally overhauled
May 27, 2017 | Polaris ATV
I have a 1999 sportsman 500 4x4 that has now power
i have a polaris magnum 330 4x4 with the same problem mine still does it because i havent did anything but i think ive got water in my oil but in low gear it pulls fine
Jan 09, 2010 | Polaris ATV
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
