Question about Ovens
Thermostat does not match wiring diagram
I ordered a new thermostat for my old gaffers & sattler gas wall oven and realized when I got it today that it does not match the wiring diagram and im not quite sure how to connect it. the old part number was 993-327 and the new one is 993-321. basically the old part had the contacts straight down as you can see by this http://imageshack.us/photo/my-images/96/wiringdiagram.jpg/ and the new one has them off to the left side
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: We have a 37 year
Hi. Take the screws out around the frame and the oven will slide out of the cabinet. good luck.
Posted on Feb 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Posted on Jun 26, 2009
  • 1891 Answers
SOURCE: Westinghouse POC700M Ultimate One wall oven. We
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Posted on Nov 22, 2009
SOURCE: HEATING ELEMENT GAFFERS & SATTLER BUILT-IN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Posted on Nov 22, 2010
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Nov 18, 2010 | Ovens
When I turn on my oven it come on full blast
good luck finding someone that knows about your oven.
if you can remove the wire to the broil element you might get a few more years out of this oven.
it probably has a burnt contact, stuck, in the broil circuit. it most likely wont be available to replace so you will have to replace the whole unit or remove the wire.
when you find this out you will probably have to do cabinet remodeling to make a new oven fit.
try the wire trick and then prepare to replace the unit soon.
Jan 08, 2010 | Ovens
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
Dec 22, 2009 | Ovens
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Ovens Logo
107 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
