Question about Humminbird Piranhamax 220 Fishfinder
Hooked it up wrong to the battery
I hooked it up wrong to the boat battery
How can I hook two 12 volt batteries together to produce 24 volt output. I have replaced the two older batteries but have not been able to get the two new batteries to produce the necessary 24volts
Hooking up 2 batteries (IN SERIES) will give you 24 volts. First make sure the 2 batteries are exactly the same. Do not use mismatched batteries. Hook the POSITIVE of first battery to the NEGATIVE of the second battery. Then hook your LEADS ( hot and ground) to the 2 remaining posts. That will give you 24 volts. When charging the batteries with a charger, hook the charger up to the LEAD POSTS.
Apr 26, 2015 | Boating
Raytheon R21XX/R41XX Radar home use or testing ? boat,ship radar
That model is meant for marine (boat) use. You can pre-test it anywhere as long as you are providing the proper power source. It's meant for 12vdc. If you have a marine battery, or a car battery handy, just power it up from that. You do not want to plug it in to household current, you would fry it in a matter of seconds. I would suggest hooking it up to the power 12v outlet in your car of truck to test it.
Jun 08, 2014 | Raytheon Radio Communications
Boat won't start and battery is charged
We have the exact same problem with our eclipse. Went out and bought a brand new battery and still it will not turn over?? Have you found out what was wrong with your boat?
Jul 17, 2010 | Boating
Convert portable batteries to 12 volt boat ststem, Eagle Super Pro I.D
Cut the battery wires where they hook up to the machine. When cut they might need some more wire spliced to them. Get some alligator clips to put on your red and black wires to hook right to your boat battery. When not in use on the boat get a small 12 volt battery, cheaper then two 6 volt disposables.
Aug 10, 2009 | Eagle Fishmark 320 Portable Fishfinder
Boat battery charging issue
Hook up a differant bank and see if it says charged, check volts of battery must read 12.6 volts to be fully charged. If it dont bad battery
Jim OMC Retired Mech
Jul 01, 2009 | Boating
Raymarine gps sounder
This is a common problem if the GPS is hooked up to an electronic heading sensor such as an autopilot. If the heading sensor is not calibrated properly, the boat will appear to be facing the wrong direction.
If you have an autopilot, consult the installation guide and perform the sea trial procedures. That should get your boat lined up properly.
Jul 17, 2008 | Raymarine GPS
Humminbird Piranhamax 220 Fishfinder Logo
26 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
