PROMAC LCD TV in Standby Mode
How can i set my PROMAC LCD TV to a Manual Mode, because it is in Standby Mode and the remote is not working. PLease help...
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
Check the remote control for its infrared emission. Without remote control, you can't set it out of standby. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. There is one post have details about how to check and repair remote controls. http://electronicshelponline.blogspot.com/
Posted on Apr 23, 2013
4 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: TV in standby mode
Hi iducher the tv power supply is faulty have a tech repair your tv.good luck
Posted on Apr 26, 2007
SOURCE: TV/DVD unit locked in Standby mode
If you still have the TV:
Common cure for "stuck in standby"
1. Unplug from mains
2. Press main power switch on/off about 20 times
3. wait about 5 minutes
4. plug it back in and try turning it on as normal (i.e into stand-by then CH+ etc)
It has worked for me on about 8/10 TV sets found stuck this way
Posted on Apr 21, 2009
ginko
  • 19396 Answers
SOURCE: T.V. Engineer working on a LG 3000 model: When you
Before replacing the main board, the PSU should have been tested. This TVs PSU provides power on different voltages, and each voltage is controlled through a low DC control line from main board. A defective PSU may turn off and restart by itself.
In real word I repair many LCD TVs. I do not get tired of repeating that LCD TVs are very different from home computers. Repairing by simply board swapping does not work. Although this units have few parts, the working process of the TV does not allow identifying reasons of faults from symptoms (with a PC you can often tell), parts are expensive, and testing is always necessary.
In your case for example the problem is likely a faulty PSU, but a bad grounding caused by missing screw may also cause the problem. The PSU, which is likely culprit, must be tested by jumping the control lines and reading volts to main board. This is made more difficult by the fact that the TV is forcing shut down, and turning volts off continuously.
Posted on Sep 13, 2010
My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
or
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
or
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
or
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Oct 04, 2008 | Sony KV-32XBR85 TV
What is the code for Promac LCD TV using RCA remote
It seems that this brand TV has no set-up codes with RCA Remote control. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | RCA Televison & Video
Got a tv lcd f4010ms promac.my son using the remote and the picture git worse .how do i reset the tv in the remote coz last time the technician only reset in the remote .i dont know the code anybody c
You've to enter its service mode option to reset it into factory settings. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Jan 05, 2015 | Televison & Video
Remote Control Not working
JUST GOOGLE THE BRAND OF THE REMOTE AND YOU WILL FIND A CODE FOR IT.
Jan 27, 2014 | Televison & Video
When i turn it on it clicks and the goes right back off
New set?
If you're turning almost any TV on by the manual power switch on it, thats Standby mode.
The next step it's waiting for is the ON command from the remote control.
There are two main methods remotes use to go to ON from Standby:
Press the Power button for both on and off commands
Press any 1-10 (or 1-0) button for on, press power button for off.
Sep 24, 2011 | Sanyo DP42848 LCD TV
Remote code for promac tv
hi everyone can you help me to get the code for promac lcd tv i have chunghop universal RM-133e remote but i dont have a code for my promac tv. . .
Jul 11, 2011 | Universal Remote Control Remote Control
My tv power comes on with a snowy black and white background but after some time it goes automatically into standby mode.
Hi camadino ,
You need to set the auto standby mode to a long time for e.g. 3 hours or disable it.
Check the settings for standby mode and you would be able to set it accordingly.
You could access the TV's settings via the panel on the TV or via the remote which comes with it.
Hope this helps ...:)
May 10, 2011 | Sony KLV32S400A 32 in. LCD TV
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
