Question about Sewing Machines
Problems with Yamato serger thread tension and have no manual. To loosen the tension for wooly knitting thread, should the tension be adjusted to the right or left?
2 Suggested Answers
sew dutch
  • 25 Answers
SOURCE: Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
Posted on May 25, 2009
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
How to adjust the tension of the serger machine
It helps a lot to use 4 different colors so it is easier to tell which thread tension needs adjustment.
Sergers have tension dials for every thread. Start out with the dials set at the midway point between high & low numbers (this is the factory standard, however, the settings can change with machine use and wear). Be sure to RAISE the presser foot while thread every thread--this allows the tension disks to open. It also helps to grab the thread with one hand below the thread tree and, with the other hand, grab the thread below the tension disk and give it a little tug to insure the thread is seated all the way in the tension disk. Check to make sure every thread is threaded in the proper order (consult the owner's manual) and that every thread follows the correct path.
Test. Tweak the thread tensions. Higher number usually tightens a loose tension, lower number loosens. The correct tension is when the looper threads meet at the very edge of the fabric without causing fabric pucker; needle threads should be smooth with no loops or pulliing.
Mar 10, 2016 | Sewing Machines
I am having adjustment problems on my machine, it did not have an owners manual. missing stitches and bunching up underneath the meterial
Have you changed the needle ? Is the fabric a knit ? If the needle has been used for awhile, it may be dull. Many modern fibres are quite hard on needles, which need to be replaced fairly often.
Many knit fabrics require a ball point or Q needle.. [ Kenmore\'s brand of ball point knit needle]. Many knits are notorious for causing skipped stitches and a special needle for knits can really help with this.
If thread is bunching up, is this underneath or on top of the fabric ?
If it is underneath, the top tension may need to be adjusted. Mal adjusted top tension can cause a lot of problems, and the mechanism that controls it can become worn and may need service or replacement.
Oct 01, 2014 | Kenmore Sewing Machines
Setting the tension for a 3 thread wide serger stitch
The tension depends on the thickness of the knits. Have you checked with the manufacturer about this problem? Check their website too, you may find the answer there. I wish I could help more. Good Luck!
Apr 14, 2014 | Sewing Machines
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
Thread for a rolled hem on the bernina 800d
HI
I would reccommend regular serger thread for the right needle (left needle is removed) and the lower looper. and use wooly nylon in the upper looper
The tensions on the needle should remain at 5-6 upper looper thread tension should be about 3-4
and the lower looper tension at about 8
contact me at Sewaway@shaw.ca if you have further quetions
Wayne Buss
Apr 22, 2010 | Sewing Machines
Serger tension is off and I can't get it adjusted properly. I have a Necchi Lock machine that is 25 years old and it's been a gem. Do you know how to adjust the tension?
Do you still have the instruction manual for the machine? If you do, you get a great big gold star!
Unless this model has auto tension, there should be a tension knob or lever on each thread feed.
Open the tensions (set at zero). No access to the tension controls, raise the presser foot and this will open the tensions, if the controls are okay.
Re-thread the serger and then set the tension controls back to mid-range or lower the presser foot to re-set the auto tension function.
With the presser foot down, stitch a chain of threads and if they do not "knit" as the should - the serger needs to visit a repair shop.
Service for a serger usually begins around $100.
It could be just the timing needs to be adjusted.
If the tension controls need new springs or the controls needs to be replaced, this will add to the repair cost.
Mar 29, 2010 | Sewing Machines
Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Mar 24, 2010 | Singer 14SH654
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
