Question about Toys
SLIDE JAMMED - Toys
Can not remove bit from 11223 EVS bosch rotohammer
Hopefully you don't have the wrong shank jammed in this because it can be a costly repair.
- Using a screwdriver, pull off the rubber dust cap #21 at the end of the nose & slide it out of your way.
- The shell #22 will also slide up out of your way
- Using a pick or small screwdriver, remove the snap ring #143 at the end of the nose & slide the 2 metal #144 & 1 rubber washer #31 out of your way
Slide the spacer tube #24 & stop sleeve #25 out of your way
Now you can access the 2 pawls #26 that hold the bit in place - you will have to assess what is jammed from here .
As I said, if you have a spline bit jammed in this SDS nose you may be looking at a whole new barrel because even if you extract the bit most of the time is does damage to the bit sleeve in the barrel.
Apr 08, 2014 | Bosch Drills
How to free jammed slide on SW40VE
I believe this is a pistol not a typewriter.
DickyO
Apr 26, 2012 | Office Equipment & Supplies
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
How to remove carosel. How to remove jammed slide.
depending on the model (which would be helpful here), there is a button or lever near the slide opening into the projector to release the tray. but if the slide is stuck halfway, remove the top loading ring on the tray and pull the slide out through the top first.
Oct 25, 2009 | Kodak Office Equipment & Supplies
Jammed cartridge in Lexmark P315 photo printer
You may slide the cartridge.Its ok to do that, just slide to ur right.
May 28, 2009 | Lexmark P315 Photo Printer with 2.5" LCD...
Slide mechanism jammed
Try squirting WD 40 all over the rails and into the bearings...Your bearings could have rusted in place and won't turn. Or maybe one is rusted and the other turns a bit...You could use a good pair of vice grips to remove that stripped screw.if that will give you better access..
I haven't ever seen one jammed up like that though...
Otherwise, you might look up the parts diagram and see what you're getting into there, if there's anything that could have broken off inside that's hanging up..link here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 26, 2009 | Makita 10" Dual Slide Compound Miter Saw...
Passenger seat does not slide back anymore
Check the seats sliding unit it may be struck or something may be jammed the unit or the release unit may locked or jammed............
May 20, 2008 | 2003 Jeep Liberty
Film back jammed
Ok, The dark slide has to be in the right way. A small tab sticks out of one end that matches a small slot below the main slot where you put the dark slide. The tab will sometimes miss the release arm in that smaller slot
Jan 27, 2008 | Bronica SQ-A Medium Format Camera
Toys Logo
88 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
