Question about Casio Mens Wave Ceptor watch WV-58A-1AV
How to unmute sound - Casio Mens Wave Ceptor watch WV-58A-1AV
I can't get the tv to have the surround sound work
This effect varies greatly from one set to another, it may only barely perceptible.
Dec 25, 2014 | Sony DAV-TZ140 Home Cinema System Home...
Replaced batteries in Casio Pathfinder watch. Functions work, but alarm does not sound.
there are two reasons for this while changing the battery the small coil sping that operates the alarm as fell out or you av put the back on in the wrong position
Jan 20, 2013 | Watches
How can unmute my watch. even the alarm tone is on mute.
Um, well I had the same problem on my baby-g watch, but i fixed it so here:
- dunno if this'll work, but hold the bottom left button for a long time. never let go till you here a beeping noise. like DO NOT let go. like this is a g-shock and not a baby-g, i dunno where the mute is indicated, but u might see it somewhere. so, just do that dunno if it works as, again, i have a baby-g. good luck! :)
Nov 30, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
The alarm sound in my casio 526 watch doesn't work. The alrm fashes but no sound.
Make sure when you change the battey that the back is put back the proper way. Otherwise the sound mechanism isn't connected right.
Sep 20, 2009 | Casio Watches
I have a Nike Triax 35 and just had the battery replaced. Now there is no sound when the alarm goes off. The sound icon flashes but I can't hear anything. How do i get the sound back?
were did you get your battery replace at. becuse when you take the watch apart there is a little spring that makes contact to the bottom of the case back to a metal thing that is glued to the case back. Witch is the speeker for sound. If they lost this spring no sound. :(
Jul 13, 2009 | Nike Triax C-3 Wrist Watch
Citizen BL717459L - Alarm sound is too low
No, there is nothing wrong with the alarm in your watch.
The sound in all watches are generated by passing vibrations to the metal tweeter which is connected to the watch caseback inside the watch. As the surface of the watch is quite small, there is not efficient power to spred the vibrations over the caseback surface, hence low volume of the alarm. No wristwatch in the world is capable of loud alarm sound yet. This is something the scientists have to work with.
The plastic protector is definetly affecting the volume. Take it off and you will notice slightly better sound. This protector actually is ment to protect watch caseback from scratches prior to selling it to the customer and have no use after that. In fact it only collects the dirt and bacteria and can affect your skin as the caseback as well.
Another sound improvement can be the new battery if the original is underpowered. Alarm feature uses the most of the energy stored in battery and the power consumption is higher than all watch movement parts put together.
Rate me, please.
Mar 12, 2009 | Citizen BL717459L Watch
I want to download sound card drivers
I want sound card driver
CS4280 - CM EP
ASAJBG9915
Jun 14, 2008 | Timex 27191 Wristwatch
How do you switch off the sound
For my casio calculator watch (mod no. 437438), I go into the calculator mode and press the button below the one that pops out at the side (don't know the correct term for it sorry). Pressing that button will mute the sounds of your watch, if you want to retrieve the sound, do the same thing again.
Mar 28, 2008 | Watches
Resetting sound
Could the jeweler have inadvertently damaged the beeper in the watch when he changed the battery? I'd tell hime the problem, ask him to restore the sound and see what he says ("oops" is a bad sign).
Lenny
Feb 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
No sound
Make sure the sound is turned on the unit. Press and hold the lower left button for a few seconds and you should see a little Sirus like pic on your watch. If you have that and no sound then you have a problem. Maybe try taking the battery out and reinstalling after a few minutes. If nothing works then your choice would be to send the watch to get repaired or live with it. The heart rate does flash if you are under or over your target rates. Good luck
Jan 24, 2008 | Polar M32 Heart Rate Monitor Watch
Casio Mens Wave Ceptor watch WV-58A-1AV Logo
16 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
