Question about Saws
Replace blade on macallister cod305dlsm
Re-assemble guard
CDNMoose
  • 15 Answers
SOURCE: Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Posted on Feb 19, 2009
brewerstool
  • 141 Answers
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Posted on Sep 28, 2009
Testimonial: "Got it. Thanks"
  • 157 Answers
SOURCE: how to replace saw blade and re assemble the blade
Hello. The guard does not have to be taken apart when changing the blade. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Posted on Apr 05, 2011
rowdy45176
  • 2176 Answers
SOURCE: How do I assemble the blade guard for my Makita
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
Posted on May 04, 2011
rowdy45176
  • 2176 Answers
SOURCE: How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Posted on Jul 12, 2011
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Lasko table fan model 4916 , I would like to know how to take it apart to clean it.
Kevin-
LASKO's typically have latches or clips that hold the front fan guard to the back fan guard.
Flip latches or carefully remove the plastic clips. This will reveal the 'nut' that secures the fan 'blade assembly'. Note, the nut has 'lefthand' thread so to remove it, turn it clockwise to remove.
The fan blade assembly can be pulled / wiggled free.
The fan blade assembly can be washed with water / wiped with a cloth.
Another nut (righthand thread) secures the back half of the fan guard, remove it and remove the guard.
That should do it.
Dec 18, 2014 | Dryers
How to reinstall saw guard on Mac Allister MAC185LS?
Never heard of this brand of saw. A Google search indicates that MacAllister only makes big earth moving equipment. Otherwise, most saws have an appropriate washer and retaining clip that holds the guard on. And you'll need the original spring to return the guard to the closed position every time you use it. Then there are two shaped washers that fit on the armature that have a 5/8" shoulder to fit a normal saw blade. Finally there is the nut that holds everything on. Hope you didn't lose all these parts. If you did, go to eReplacementparts.com and and enter your make and model. If they don't have what you need you might be plum out of luck. But a new saw.
Oct 03, 2014 | Saws
How to replace saw blade and re assemble the blade guard
Oct 10, 2010 | Makita 10" Miter Saw LS1030N
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
Jan 01, 2009 | Makita 10" Miter Saw LS1030N
Saws Logo
215 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
