Question about Garden
Troy-bilt roto tiller-power/carburetor diagram rebuild
I need i detailed picture on how to put the carburetor back on the tiller,where each spring goes and each lever goes.i think thats what you call the little metal rods?theres 3,2 are long and 1 is short.and help with something call speed control and stop lever.can you help?oh and this tiller is a pony model/briggs&strtton motor....
model #130202 type HB-66 code 86062307
  • Anonymous Mar 24, 2009
    did that,no answer back!!!!
  • DAN J HULL Mar 15, 2012
    I have the same problem, and need the very same kind of help !! had to repalce gas tank and every thing and now i'm stuck on this need a picture that shows how/where every thing fits and where it goes. Dan
5 Suggested Answers
bbreton
  • 437 Answers
SOURCE: i take the wire off the magnett coil it will crank
sounds like 2 possibilities, the wire to the coil is shorted to the frame or the ignition switch is bad. I would try and check the route of the wire for the coil, it is the kill wire and if it is grounded it will not allow the coil to fire the spark plug.
Posted on Jan 05, 2010
SOURCE: What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Posted on Apr 27, 2009
SOURCE: tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Posted on May 20, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
  • 12 Answers
SOURCE: i have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Posted on Jul 27, 2010
Need gasket carbereter kit
I have been trying to help you. It appears that the "pony" model has submodels as well I will send you this link and please post back with which model is yours. Model numbers are the BIGGEST help I get, because I can research this machine all day and not have the correct carburetor for your exact model. Here are the current Troy Bilt "Pony" Tillers for sale on the net.
http://www.bing.com/shopping/search?q=Troy+Bilt+Pony+Tiller&FORM=HURE
Again, please reply. I will get your reply and continue to assist you. Thanks!
Jul 04, 2011 | Troy-Bilt Pony Garden Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Hi there i have speedy hoe model#352 i did tune it up and now i do not know how to put back small spring which is close to air filter ,and there is also about 1''of wire that conects to carburetor and...
I'm sorry I don't have a solution for you but I have a similar situation. Don't know what goes where. Do you have an Owners Manual for that unit? Much appreciated if could get a PDF copy e-mailed to me.
Feb 13, 2010 | Troy-Bilt Pony Garden Tiller
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Jun 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need a manual
here is the Tuffy webpage at the troybuilt.com... directly under the photo of the tiller is a gray "download manual" link...
best wishes,
k
May 28, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
May 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing the drive belt
pull the bracket
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
6,751 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
