Question about Watches
Removing links from watch
Is there an easy way to remove links? It's a fossil es2197 wrist watch
  • 2,334 Answers
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 12, 2009
  • mbnewman Oct 07, 2010
    Thanks, this worked just fine removing the pins. Iwas really stumped until I read your post.
How to remove links from a metal fossil watch band
mcdevito75 here, To reove the links you"ll need a special tool called a link remover available on ebay, or you can look for a small watch repair shop in your area for about the same cost of the tool and save on delivery time as shop can do the job right away.
Aug 07, 2010 | Fossil AM3726 Wrist Watch
How to take out fossil watch links without breaking it
mcdevito75 here, You"d need a special tool called a link remover tool available on ebay but, the cost and time for delivery are the same as you looking for a small watch repair shop in your area to remove these links for you, hold onto the se removed links just in case you ever want to re-install them.
Jul 03, 2010 | Fossil AM3726 Wrist Watch
I am trying to remove a link from my fossil watch. How do I do it?
hello. Your best bet is to take the watch into a jewelry store.
They have a special tool designed to remove the link pins with out damaging anything. They may charge a few dollars but it would be worth it. J.
May 20, 2010 | Fossil AM3726 Wrist Watch
ES9439 Wrist Watch: what battery doe the Fossil ES9439 Wrist Watch tak...
Link
Please visit above link for your Fossil battery requirement. Kindly contact Customer Service Team for further details.
Thank you.
May 18, 2010 | Fossil ES9439 Wrist Watch
I have a Fossil analog / date watch and need to remove a couple of links. The arrows on each link point in opposite directions. I tryed pulling the ends the respective directions to no success
There are some instructions on the Fossil web site but they are not too easy to find.
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care" and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions".
Feb 13, 2010 | Fossil AM3726 Wrist Watch
Watch band link removal
Find out here in my tips.
Feb 04, 2010 | Fossil AM3726 Wrist Watch
How do i remove links from a fossil metal band.. watch
Look for screws in the links or pins. Sometimes "hairpin" looking keepers are used to remove a link.
Dec 05, 2009 | Fossil AM3726 Wrist Watch
I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
Mar 09, 2008 | Fossil CH2331 Wrist Watch
Fossil watch band adjustment
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Watch band
How can I remove a link from my watch band to fiit my wrist?
Dec 22, 2007 | Fossil AM 3688 Wrist Watch
Watches Logo
485 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
